Home > Puma (Tdci) > Door locking issue
camelman
Door locking issue
Any puma owners have an issue with their doors self locking? Only happens on the drivers door intermittently. Press the external push button or pull the internal handle and it locks the door Neutral
This then fires the central locking which locks all the doors!
Post #954830 7th Jun 2022 5:48pm
markb110
Is the yellow wire damage within the rubber conduit between the bulkhead and door.
It happened to me, you can either get a complete loom or pull out the wire either side of the conduit then add a repair piece then pull the bulkhead side back into the rubber housing.
I went for the repair as i am a cheapskate.... Very Happy
Post #954855 7th Jun 2022 7:05pm
Craig-C
United Kingdom 2007 Defender 90 Puma 2.4 HT Rimini Red
Yes, I had the same. Turned out to be a linkage in the door was partially seized up. The plastic rod going to it was flexing enough to unlock but would then re-lock its self. Check if the plunger is only coming part way up. Mine was.
Good luck. FFRR TDV8 sold
PUMA 90 :0[==]0:
90 TD5 CSW XS
MX5 (NC)
BMW 320
BMW 1200 GS Adventure
SUZUKI HAYABUSA
Post #954862 7th Jun 2022 7:25pm
