Home > Technical > Height/dimensions of SW/hardtop “back”
Dave12345
United Kingdom 1989 Defender 90 300 Tdi PU Keswick Green
So I’ve recently bought a SW converted to pickup but want to convert it back.
Trouble is I have an up and over garage door and it’s already very very tight to the roof, and the hardtop will be a bit taller at the back due to the slight rake.
I’ve googled dimensions but there’s so much variation in answers I’d like to just work out what my specific defender would sit at with it’s own springs and tyre combo. Irrational perhaps, but I’d rather not spend a lot of money buying the side panels and roof for them not to fit.
Could someone be a hero and measure the height of the back from capping to top of roof for me please? I’ve tried googling or finding the part online with dimensions but to no avail. The below, effectively:
My defender sits exactly 52 inches from floor to top of tailgate, and my garage door frame is 79 inches high. Fingers crossed.
Hugely appreciated
Dave
Post #954571 4th Jun 2022 9:41pm
Mo Murphy
Dave,
28¼ inches to the roof plus 1 inch if you get an early external ribbed roof.
HTH
50 Shades of Pennine Grey
Post #954585 5th Jun 2022 8:34am
Dave12345
Much appreciated Mo.
That’s a shame looks like it won’t fit then. I reckon it’d lower the 1/4inch with the additional weight on the back, plus I could consider alive comfort springs so not all lost. Something to think about. Thanks for confirming.
Post #954594 5th Jun 2022 10:32am
Dinnu
My 90 is on worn 235/85 tyres but also replaced the rear springs with NRC2119 and sits at 77 1/4” from the ground to the roof. Note that mine is a CSW so a tad heavier on the rear as I measured 1” lower compared to a HT with same springs on the rear.
http://red90.ca/rovers/springinfo.html
Keep in mind that you will be adding the roof, sides, rear door, spare wheel, perhaps a spare wheel carrier.. those add up. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #954604 5th Jun 2022 11:52am
Dave12345
Am I right in saying that NRC2119 should be a 1” lift as well? That’s promising if so.
Post #954605 5th Jun 2022 11:59am
Dinnu
No, because NRC2119 has a softer spring rate, so will compress more and will sit a bit lower even though it is 1” longer (free length) compared to default HT springs.
They will also give you a softer ride when unladen. If you are planning to load the rear a lot, maybe those springs are too soft. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #954616 5th Jun 2022 2:32pm
Dave12345
Thanks for that - every day’s a school day
Post #954622 5th Jun 2022 3:54pm
markb110
No idea if this will work for you but i get my 90 into my garage with an up and over door with some modifications.
I (with a second pair of hands) moved the frame up as far as i could, about an inch and a half.
I then cut the top edge off the fibre glass door where it wraps around the frame (as it was catching)
The door handle shaft on the inside (with the three latch cables connected to the plastic inner handle, i cut the shaft down and then re-tapped it so to re-attached the inner handle.
I then attached a rubber strip along the bottom edge to prevent leaves and the wind blowing through in the winter.
The result is that the 90 is hidden from view over night and when we are away.
One the door runner, closest to the door, i have drilled a hole and fit a padlock to it so the door cannot be forced open from the outside.
My 90 is on 265's, a two inch lift and a roll cage, just to make my life easy...... Whistle
I hope that this helps in some way
Good luck
Post #954644 5th Jun 2022 7:36pm
Avelingporter
I got a friends 90 HT to try before I took delivery of my 90. The up and over door handle spigot had 1/4" clearance at best. Too tight for comfort. So I changed the garage door to a roller shutter door. Now 3" + clearance. Might just be easier to change the door. I think it was about £600 all in fitted. So in the great scheme of things not too much to get the 90 in the garage and secure.
Post #955005 9th Jun 2022 8:19am
Dave12345
Good luck
Thanks that’s very useful as I’ve been looking at the frame wondering if it was raisable so good to know it’s potentially doable. I’ve bought a roof etc to collect next weekend hopefully so that can be this week’s project.
Rolling door is a nice idea too if all else fails.
Can’t believe how many genuinely useful responses I’ve had on this and my other thread, what a nice forum this is!
Post #955238 11th Jun 2022 10:19pm
