Home > Technical > Complete loss of power at 3000rpm
Van Diesel
United Kingdom 1986 Defender 90 V8 Petrol ST Auto Pennine Grey
Hoping someone has some clues on this
90 pick up with a 3.9 V8 from a 93 Disco. Starts and runs fine but a bit rich.
Sitting still in neutral or park (auto box) I can rev it up into the red if I want to. Get going down the road and just about at 3000rpm, I lose all power, throttle goes dead. if I pump throttle I can hear the K&N sucking air but noting else. After about 2 or 3 seconds, once revs have dropped back, throttle comes back to life.
ECU, amp and Magnecour leads about 5 years old from RPI. New Idle air control valve. No issue before this was changed apart from high idle, which the new IACV cured but now this problem. Related?
Have checked inputs with multimeter on TPS lead but with the plug type on the wires i can't really check output on signal wire. Even with the TPS unplugged, I'm still getting issues so don't think this is the cause.
Any ideas?
Post #954503 3rd Jun 2022 6:03pm
rallysteve
Have you checked if the vacuum advance is working on the dizzy?
I would also check the ignition timing.
Post #954506 3rd Jun 2022 7:50pm
Is it turbo charged or NA?
If turbo charged then maybe Turbo related? I’m no expert but I mention it as when I had issues with mine with the turbo actuation it would rev fine but when under load I.E. whilst driving you’d just have very little power indeed and feel completely gutless as the turbo was not active at all and no boost.
Just something to think about, and boost leaks etc as well. WeWillWin🇬🇧🇺🇸
Post #954516 3rd Jun 2022 10:18pm
discomog
Is it a faulty sensor (possibly Lambda) causing it to go into limp mode? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #954523 4th Jun 2022 8:26am
Van Diesel
@Rallysteve
Vacuum advance seems ok. Dizzy is fairly new. I may get the timing checked.
@custom90steve
It's normally aspirated so no turbo to effect things.
@discomog
It doesn't really go into limp mode, it just loses all power under the pedal for a few seconds, once the revs drop off it's back to normal, until you hit 3000rpm again.
I'm wondering if the ECU is picking up a wrong signal from the TPS? Like it's telling the ECU that the pedal is flat to the floor, or that sort of thing.
Can't think it's fuel related as guessing it would splutter before cutting out. It revs strongly all the way up to around 3k then it's like someone cut the throttle cable. I've checked the throttle assembly and it's all smooth, no snagging. Plus it revs in neutral to the red line with no issues.
Post #954540 4th Jun 2022 2:22pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
Crank Sensor?
I've had one break down before (on a different engine entirely) and it coped ok at lower rev's, but showed faults at higher rpms.
Post #954543 4th Jun 2022 2:49pm
Van Diesel
I've just uploaded a couple of crappy quality videos to Youtube to see if it helps anyone.
This one you hear it die and the short time it takes to come back to life before it dies again. Sounds like i'm lifting off, but I'm not.
https://www.youtube.com/shorts/J_66WYBCCgo
This one just cutting out as it hits 3k rpm
https://www.youtube.com/watch?v=WCH1hAFEGFc
Post #954545 4th Jun 2022 3:09pm
discomog
I'd agree with you, it certainly doesn't sound like a fuel problem. Don't know if you've had a chance to check ignition timing as someone suggested but I doubt it's that - my 3.5 EFI is fairly critical on timing but you soon know about it as it either pinks under throttle or runs on after switching off. Sensor/ECU seems to be the most likely. Defender 90XS SW
Morgan Plus 8
Post #954590 5th Jun 2022 10:43am
Van Diesel
Not had a chance to get timing checked but no pinking or symptoms you'd associate with timing.
I think it's a sensor of some sort or an ECU issue?
Could it be a temperature sensor? Presumably wouldn't just cut the power if it thought it was too hot though? Same with MAF, it wouldn't just cut off there would be other signs. Throttle position sensor seems like a possible link but don't know enough about them. Would a break in the contact that the wiper follows do that?
Post #954628 5th Jun 2022 6:34pm
