Home > Puma (Tdci) > 09 Puma alarm / immobiliser as stock?
lemons
United Kingdom 2010 Defender 90 Puma 2.4 HT Santorini Black
Hello!
This could be a silly question, so bare with me... I've just picked up an 09 defender pick up that only came with one key (and no alarm fob) - it doesn't have central locking, but is there any way for me to check if this has an alarm / immobiliser without the fob? I assumed all Pumas came with this as standard
If the above is true - is there any way of getting a new fob? Or am I about the enter a whole world of pain trying to get one programmed to the car?
Thanks in advance
Post #954239 31st May 2022 9:41pm
ak615
They do , but it may need enabling, Take it to an independent
maintainer as Land rover will charge you the earth, when I had mine done they enabled it and only charged me the the price of the fobs which at the time was about 30 quid each.(Land Rover quoted me £1200 !!!!!!)
Post #954262 1st Jun 2022 7:55am
Ianh
Lemons. Yours will be the Lucas 10AS unit, it’s Green in colour and if you remove the drivers footwell speaker you can look up and see it.
There are two versions, one with central looking capabilities and one without.
Have a look at the serial number , if it’s one of these it won’t have the central locking components fitted.
AMR6431
AMR4896
YWC106270
YWC500660
However all is not lost, it can be upgraded. Have a look at this site, well worth phoning them for info
https://www.technozen-electronics.co.uk/la...-services/
Also worth Talking to Ian at remotekey https://remotekey.co.uk/land-rover-keys-re...mobiliser/
Post #954304 1st Jun 2022 1:37pm
lemons
Thanks both, super helpful! I'll get my unit sent off to Technozen to be updated (turns out it's the YWC500660 one)
Regarding adding central locking, is it just a case of purchasing 2x actuators and 2x door wiring loom kits to plug and play, or is additional wiring behind the dash required to complete it? (Trying to keep it OEM where possible)
Post #954391 2nd Jun 2022 10:06am
Ianh
Post #954403 2nd Jun 2022 11:13am
