Home > Wheels & Tyres (L663) > BF Goodrich AT KO2 265/60/20
Cheshire110
New tyres finally arrived & fitted… really happy with them.
A tad taller and a tad wider than the standard 255s, but no clearance issues at all. And not worried about the sidewalls like the Goodyear Wrangler ATs which seem to be really prone to issues.
Think the car sits really nicely on them too.
 Cheers, David
Post #938078 17th Jan 2022 5:37pm
Buz1500
Any changes in road noise or ride quality since you’ve fitted your BFGs?
Post #938134 18th Jan 2022 8:01am
Cheshire110
Certainly there will be a little more noise than the road tyres I have had on for the last few weeks, but nothing like as bad as the Duratracs or other mud terrain-style tyres. I’ve always run BFG ATs on my old defenders and always thought they’ve been a good compromise.
If anything, slightly wider and taller tyres should help the ride quality a bit, but no real noticeable change. Should be a big improvement off-road where I’ll be happier airing down a bit if needed. Cheers, David
Post #938154 18th Jan 2022 11:38am
stng110
Australia
Hi David
Any problems with rubbing when in access mode and turning the wheels hard left or right?
Simon
Post #953728 26th May 2022 7:59pm
Cheshire110
Not noticed any! Cheers, David
Post #953739 26th May 2022 8:46pm
mse
How out is the speed now, I've toyed with fitting these but don't want the miss read Mike
Post #954031 29th May 2022 9:54pm
Cheshire110
You can use any of the online calculators; but it’s only small, about +1.9% from memory. Certainly not noticeable and probably if anything just correcting for the slight ‘under read’ from factory. Cheers, David
Post #954111 30th May 2022 10:59pm
mse
Thanks, I'm still tempted, I got the tiny % but also know what the fuz are like with cash machines and average speed zones so I like to know what my speed is (and the margin Rolling with laughter ) Mike
Post #954125 31st May 2022 7:25am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I have the same BFG’s on mine and the speedo is about 1-2mph below gps measured speed👍
Post #954667 6th Jun 2022 12:25am
Cheshire110
Strictly, the error will be a % not a mph number. The 1.9% increase in rolling radius would translate to around a 1.4mph ‘under-read’ at 70mph and a c.0.7mph ‘under-read’ at 35mph.
I wouldn’t have thought that would even be enough to fully cancel out the usual built in ‘over read’ on the speedo but haven’t checked it against GPS myself. Cheers, David
Post #954787 7th Jun 2022 10:11am
mopadzi
Czech Republic
Monotube projekt (Germany) off road whells + BFG KO2 AT 265/60R20
Post #964071 5th Sep 2022 12:11pm
BruceT
South Africa
damn those look better. I just fitted 275/55/20's but those look much better with the slightly higher sidewall. My compromotives dont fit the new D300 due to the rear brakes and as its only got 400kms on it I am not brave enough to take the grinder to it yet.
 "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #972199 24th Nov 2022 6:41am
