Home > Technical > Hood drainage channel for 130 hi-cap
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi All
Bought a used set of hood sticks and hood for my 130 double cab / hi cap. looks like its missing the drainage channel that the front of the hood locates on. Does anyone know if this is the same part as used on a 90/110 with the hi-cap tubs / hood being wider I wasn't sure?
All I can find on the parts diagrams etc is MUC7923 listed for a 90/110, if anyone has got a picture of a factory 130 setup would be really handy Wink
Regards
Ben
Post #953453 24th May 2022 10:11am
benspray
quick edit
The front of the hood doesn't look like theres anywhere for the alloy channel to go either so not sure quite how it goes together or whether not all hoods use that front fixing?
Post #953454 24th May 2022 10:19am
benspray
I'm thinking the series 3 HCPU diagram is more correct for the 130? so the hood retains to the rear tub rather than the rear cab/window panel?
https://www.lrworkshop.com/diagrams/land-r...hcpu_511#1
Post #953462 24th May 2022 10:48am
Honeyman
Netherlands 2011 Defender 130 Puma 2.4 HCPU Sumatra Black
Hi there,
This is what I have (MY2011 130) - hood fits to the (shoddy looking) piece of alu angle on the tub itself & not the cab. It was actually fitted upside down when I got the car, and therefore did nothing!
 2011MY 130 HCPU: daily driver
1979MY RRC 2-door: on the drive, in the garage & in a shed - all at the same time.
Post #953562 25th May 2022 10:52am
benspray
Cool, thanks
That part at least is cheap enough, looks like bolts rather than the £10+ each dzus are the way to go too looking at yours.
Ben
Post #953565 25th May 2022 10:58am
Honeyman
Thumbs Up
The bolts *look* factory - they are identical in style & finish to many others around the vehicle (tailgate catch bolts, rear seat retaining bolts etc). But all they have to do is hold down a flimsy piece of angle. Good luck… 2011MY 130 HCPU: daily driver
Post #953566 25th May 2022 11:05am
