![]() | Home > Faults & Fixes (L663) > Electrical Fault & Engine Check |
swisslad Member Since: 06 Feb 2021 Location: Portsmouth Posts: 20 ![]() ![]() |
Car is now booked in for Friday - let's see....
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 291 ![]() ![]() |
Do you do mostly short trips? Warnings like this often crop up when the battery gets a bit low, usually fixed by a run of at least 30 minutes. Will be interested to hear what the dealer says.
I do a daily 20 mile roundtrip - mostly in EV mode.
Not being technical, I can only suspect that perhaps, in EV mode, it somehow failed to charge the 12V standard car battery - I presume all electrics run off that, still, as normal? |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Swisslad - in addition to my 2020 D240 Defender I run a Mini EV and with regard to the 12v battery in that the battery management system will divert energy from the main HV battery to top up the 12v battery when it drops low, however if the motive battery is below about 15% (bear in mind the Mini’s HV battery is only 32kwH capacity) it will not divert charge to the 12v system in case you won’t have enough charge to drive. Could it be possible that you have run both the 12v and motive batteries down to such a level that there is no longer enough charge in the HV battery to allow recharging of the 12v? My previous Mini Countryman PHEV did the same as the Mini and it only had a 7.5kWh HV/motive battery. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Got car back today. Dealer performed a BCCM software update (battery charge control module) and further replaced the battery itself as showing as defective. Also lubricated window to rectify rattle when slightly open.
