Home > V8 > Factory 3.5 V8 FEAD Setup
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Hi,
I'm currently undertaking a 3.5 V8 conversion on my '89 90, it's a v-belt engine out of a RRC (not a serpentine engine). I'm hoping to get as close to a true factory setup as possible.
I'm really after some pictures from someone with a factory-fitted 3.5 showing the front end accessory drive setup - ideally details of:
- The alternator location and bracketry
- The power steering pump and bracketry
- The oil filter setup - does the on-engine filter mount foul on the steering box for a RHD car?
- Location/setup of belt tensioners
- Anything else I need to consider around the front of the engine (I'm thinking electric fan setup rather than viscous)
Any help would be greatly appreciated,
Cheers, Matt. Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #953241 22nd May 2022 8:29pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Matt,
I have a factory 3.5 V8 in a 1985 Ninety. If you pm me your email address I’ll try to get a few photos to you.
Post #953286 23rd May 2022 9:04am
trickster5000
Ah perfect cheers, I'll drop you a message now Thumbs Up Matt.
Post #953324 23rd May 2022 12:17pm
Ranger 6
United Kingdom 1988 Defender 90 V8 Petrol CSW Rimini Red
Don't know if this is of any use? 1988 Factory 3.5 CSW
I would add that the fan has been replaced with electric ones, and it does have a snorkel.
Let me know if you need any more? 90 V8 CSW - 1988
Post #953493 24th May 2022 3:10pm
trickster5000
Yeah they're great cheers, I think I need to get hold of the tensioning bracket for the top mount of the alternator - how does the bottom bolt mount onto the block/head?
Also is the oil filter just mounted in the standard Rover V8 position on the oil pump housing at approx 45 deg angle? Or is there some kind of remote relocation kit?
Thanks for your help, Matt.
Post #953509 24th May 2022 5:53pm
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
I'm looking for the same setup to fit onto the 3.9 in one of my trucks, it's a long-term project but I'll dig out the links and images from the parts book I have collected.
PM me if it's not done within a week.
Post #953535 25th May 2022 7:29am
Ranger 6
Oil filter - yes, it's the standard rover v8 position - be sure to get a Land Rover filter as the SD1 is too long and can be damaged by the axle in extreme conditions
I'll have a look at the alternator fitting - I should know as I changed it last year 90 V8 CSW - 1988
Post #954171 31st May 2022 12:49pm
trickster5000
Cheers yeah I've now got the engine in the chassis and can see there's actually loads of space between the steering box and the oil pump Thumbs Up
Alternator bracket details would still be useful, but I'm thinking of just buying the Def V8 alternator and making brackets/tensioning slots as necessary from some flat bar Matt.
Post #954173 31st May 2022 1:13pm
Ranger 6
Grabbed a couple of shots - the bracket goes into the cylinder head and the block.
Does this help?
 90 V8 CSW - 1988
Post #954180 31st May 2022 2:13pm
trickster5000
Thanks, that bracket looks a bit more complex than just a bit of flat bar, I might need a rethink Confused
Can I be a pain and ask for also a slightly wider shot of the alternator showing the belt tensioner bar and the 3 points the alternator mounts on? Cheers! Matt.
Post #954182 31st May 2022 2:21pm
Hufflepuff
Does this help Trickster? This is out of a 1989 factory v8 110 with (obviously!) the alternator removed.
 2005 Td5 90 XS
1989 V8 110 CSW
Post #954218 31st May 2022 6:32pm
trickster5000
Yes thank you that is very useful, looks like I need to try and source that big 'tray' bracket (which looks like part number 8 on this diagram) and the correct alternator.
Anyone happen to have a link or part number for the right alternator? My parts book lists a handful but doesn't really say what the difference is Matt.
Post #954227 31st May 2022 7:11pm
gbmoto
I have a genuine fully dressed 3.5 from a 110 buried in the garage, let me know if you need any more piccy's or measurements.
Post #954275 1st Jun 2022 7:44am
MercianRover
Lucas 16 or 18ACR is what the factory fitted.
Post #954676 6th Jun 2022 8:12am
MercianRover
Reminded myself about this - sorry for lack of posts but I did something silly with the links by pasting them into a OneNote but found I have deleted the page I'd put them onto. Sad
Post #954677 6th Jun 2022 8:21am
