Home > Maintenance & Modifications > Front side lights not working
Page 2 of 2 <12
spudfan
Ireland
BrickBox wrote:
K9F wrote:
Is the side lamp indicator on your instrument cluster still working? The front side lamps come off two different independent fuses and feed instrument cluster, tail lights and number plate light. A quick check to see if they are working will give you an indication if you have bulbs, fuses or earth issue.
Can someone give some guidance on this, please?
My lamp indicator on the instrument cluster has gone out, along with my front side lights and rear tail lights. Indicators/fog and front main lights still work. I also think the instrument cluster bulbs and the centre console bulb has gone out. All in one go…
I’m still a newbie to Defenders, so still working out what’s where etc.
I stand to be corrected but I do not think that the Puma has instrument cluster bulbs. I think it is LEDs and therefore cannot be changed. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #953136 21st May 2022 8:40pm
BrickBox
Just to update this - I changed the light switch and everything is working again. Just a tiny tip - when refitting the plastic steering cover, make sure it’s seated right, otherwise you won’t be able push the light switch all the way forward for the headlights. 2008 2.4 110 Utility Station Wagon XS.
Post #957378 5th Jul 2022 5:08pm
spudfan
Ireland
Good to get the update. That is bound to be of use to somebody in the future. Thumbs Up 1982 88" 2.25 diesel
Post #957412 5th Jul 2022 11:28pm
Page 2 of 2 <12
