Home > General & Technical (L663) > Car isn't reminding me of a service |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 |
Think it's every 2 years now on new Land Rovers https://instagram.com/bentheoandrews
16th May 2022 9:24am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello dizeeduckie...Relax
"Next service due not available" "Next oil change due not available'' Wrong Terminology IMO... 'not due' or ideally show 'mileage / months' until due You could, as many do, reduce this...oil + parts inexpensive compared to engine problems. Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
16th May 2022 9:33am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
It should tell you when it’s due in the app too, along with range to run on the Adblu contents if it’s a diesel
Click image to enlarge Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! Last edited by Tim in Scotland on 16th May 2022 5:29pm. Edited 1 time in total |
16th May 2022 11:11am |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 291 |
It could do with a low battery key fob warning as well! My August 2021 wouldn’t start this morning either with the fob I always use and the spare which has never been used. LRA arrived and replaced both batteries …all ok thereafter.
Apparently they need over 3 volts to work, and because the fobs are continually live sending out rolling codes, the batteries need replacing regularly…even as low as 3 months. I seem to remember that BMWs send out a warning when the fob batteries are low. |
16th May 2022 5:28pm |
Next service due etc info in Pivi Pro will show if you drive the car off for a couple of miles in my experience. It won’t display if you just start it up on the drive - I suspect it has to do with the oil quality sensor that measures any oil dilution from incomplete DPF regens Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
16th May 2022 5:36pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
I have enough with the wife telling me what to do, if the car does the same it’s got to go…!!. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
16th May 2022 7:46pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2763 |
When you find the cost of a service, you'll be glad it's not due for 2 years.
17th May 2022 12:15pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 817 |
After hearing about all the dpf regen and oil dilution issues on the mid range JLR
products that have contributed to engine failures, I have decided to ignore LR and stuck with 6 monthly /12k km oil + filter change and a full annual service.. I plan to keep mine far longer than one on a standard lease contract yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
18th May 2022 6:20am |
Won't do it any harm, and probably a good idea.
18th May 2022 7:10am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Or of interest how much is a first service at a main dealer now? Mike
18th May 2022 10:06pm |
Buz1500 Member Since: 07 Jul 2020 Location: Cumbria Posts: 150 |
I’ve been quoted £450.
P300 SE |
18th May 2022 10:30pm |
P300 SE |
18th May 2022 10:32pm |
