Home > Puma (Tdci) > Starter motor and why it failed |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4704 |
The starter motor on the Puma began to make a funny noise on kicking so I knew attention was due. Within two weeks it stopped working but did make a very good bag of nails sound. I could not believe how quickly it collapsed. I was actually awaiting a call back from the garage about getting the starter motor seen too. The reason for this sudden catastrophic failure was due to the following.
In 2018 the Puma went into a garage who I trusted and who had served me well. The clutch was changed so I can only surmise that the starter motor was removed during this process and refitted afterwards. Here lies the problem. If you look at the diagram included in the link, you will see that there are two small dowels, TYT500020, that go on the bolts fixing the starter motor to the engine. These were not fitted when the starter motor was refitted. So over time the starter motor worked loose. The mechanic who is working on it now told me that the starter motor was loose to hand when he went to work on it. Anyway once the starter motor began making the funny noise I stopped using the Puma except locally. It is just as well as it failed completely when it was parked nose in to a wall in our yard. https://www.advancedfactors.co.uk/starter-...1181-c.asp 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
13th May 2022 12:51pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello supdfan
I went back and checked my Install... LR OEM Starter Motor LR25840 Click image to enlarge NYR500010 Click image to enlarge You can just make out the stepped (counterbored) Holes to Locate onto 'Dowels' TYT500020 Click image to enlarge My memory is that these 'Dowels' remained In Place on the Bell Housing aiding Location before drawing in Starter Motor on Assembly Click image to enlarge I have No Loose photo's of them... SKIP https://www.defender2.net/forum/topic83242.html |
13th May 2022 1:51pm |
When my starter motor was removed the mechanic said the dowels were not in place. Thank you for the photos and info. 1982 88" 2.25 diesel
13th May 2022 1:54pm |
That's the only reason the mechanic can think of as to why the dowels are not in place. I have had the vehicle from new. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
13th May 2022 1:57pm |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 377 |
either that or it left the factory without them?
13th May 2022 4:00pm |
