Home > Td5 > sump plug leak
alexatnd
sump plug leak
Hi,
Really silly simple question
About the only time I've not seen oil leaking from the sump plug on my td5 was when a local garage did an oil change for me.
Draining the oil for the next change involved a breaker bar ....with a length of pipe on it to undo the damn thing!
When i do a change I anneal the copper washer and start by tightening up to the haynes manual recommended 23 nm ... and it leaks ... had it up to 40nm still leaks
So whats the solution? Really twitchy about the gorilla approach.
Have tried PTFE tape as well to no avail
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #952052 9th May 2022 11:13am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Are you using new copper washers or reusing an old one? Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #952054 9th May 2022 11:17am
alexatnd
Always use a new one Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #952056 9th May 2022 11:23am
BaronDefenders
Make sure the threads in the sump or on the plug aren’t damaged then. It’s quite possible to damage them by over tightening. Charlie
2002 Td5 90 (SOLD)
Post #952061 9th May 2022 12:43pm
alexatnd
and if they are ?
replace sump?
drill out thread and put in an insert ? Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #952147 10th May 2022 9:42am
jimbo55
If it’s been over tightened to the point you need pipe over a breaker bar then it’s likely that the threads have been damaged either one or both of the plug and sump.
New sump plug is an easy thing to change, if it is the sump then you could probably find a decent second hand one at a reasonable price. A new sump is very expensive.
Rightly or wrongly, I always use blue hylomar to help the sealing as well as a new copper washer.
Post #952152 10th May 2022 12:10pm
BaronDefenders
alexatnd wrote:
and if they are ?
replace sump?
I’d just try and find a good secondhand sump. They’re around the £50-60 mark on eBay. Charlie
2002 Td5 90 (SOLD)
Post #952166 10th May 2022 2:34pm
landy andy
I would try fitting a Femco quick drain plug That way if it works ok, then you won’t have to disturb it next oil change.
Post #952220 10th May 2022 8:19pm
roel
I use silicon sealant. I don't know how you call it in englisch. The head gasket stuff.
It seals good and stick so you don't need to overtighten it without the fear of loosing the plug. Roel
2003 90 Td5 (2009-now)
Post #952232 11th May 2022 8:01am
