![]() | Home > Tdi > HELP!! NO DIP LIGHTS OR SIDE LIGHTS!! |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3481 ![]() ![]() ![]() |
The side lights should always be on, even if the dim dip relay is defective.
Check the switch on the steering column after verifying that all fuses are good. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
BajanRover Member Since: 12 Feb 2021 Location: Barbados Posts: 74 ![]() ![]() |
Thanks Dinnu, I will check this in the morning and update the thread.
Do the rear lights switch on on both switch positions? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Yes all the rear lights worked.....
I believe i found out what the issue was, a few days ago the Landy won't start, it won't crank over so after fiddling through and testing for current in the circuit i noticed there was no current from the terminal that would provide the 12v to the starter motor leading me to think the ignition barrel was at fault and as a result i installed my own start switch to by pass the crank terminal from the ignition barrel. So from all that fiddling it seemed as though the backside of the ignition barrell (white piece with the terminals) wasn't securely fitted back onto the ignition barrell and as a result the DIM Switch Relay was not receiving any power from the WHITE cable coming from the ignition. ![]() Click image to enlarge So now that's fixed i am in the mind frame of converting this badboy to a push to start ignition. Thanks Dinnu for your timely response bro! |
Glad you are sorted
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks mate
