Home > Maintenance & Modifications > Auto to Manual |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 485 |
Easy conversion providing you can find a V8 R380 these days? You will obviously need a LR V8 flywheel and clutch, LH gearbox mounting bracket, clutch master and pedal box and pipe work , clutch slave cyl,pushrod and fork. Would recommend a 1.4 standard Tdi/TD5 transfer box unless you want dull performance. Would be worth utillising the auto cooler on the R380 also. Same props fit fine
3rd May 2022 8:35am |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 631 |
I'd do it. The V8 is so flexible and the clutch light - its a joy to waft along and play tunes with the engine note!
Having had a manual RRC, V8 90 CSW on carbs, 2x 50th Anniversaries, and a D1 V8 manual 3.9 I decided my ideal was a 3.9 serpentine with R380. So I sourced a complete D1 V8 manual and used the engine, gearbox, exhaust and front prop etc when going from 200tdi to V8. Because all the parts transfer from D1 to Defender it makes the conversion simples. These days scrappers are suddenly looking thin on the ground. So I think the challenge is finding the bits, but it's still worth doing. I'd go down the slow-burn and find the bits you need as and when to make the conversion sensible money. If you're in a hurry it could get pricey. I agree re the 1.4 ratio, and echo all the sound advice from Linds Hanson. Bellhousing - there's a few pop up on eBay, you can also use a D2 V8 manual bellhousing and modify it to fit the inspection plate. Maybe it might be more economic to do a trade in your auto & 1.2 for a R380 long input shaft and 1.4 t box and bellhousing complete? JB @Lodelaner Instagram Youtube greenlaning and other LR related content Last edited by Lodelaner on 3rd May 2022 12:28pm. Edited 1 time in total |
3rd May 2022 9:53am |
Dont forget Discovery uses short stick box, D2 V8 has a taller 5th gear which is benificial with 1.4 transfer gearing
3rd May 2022 11:05am |
