Home > Puma (Tdci) > 2016 Defender 110 mot question's |
G55AMG Member Since: 05 Apr 2013 Location: Kuwait Posts: 5 |
Hello,
I have a 2016 Defender 110 Puma with some modifications such as tune with egr closed via software and decat pipe. Would MOT be a problem, I am thinking of importing this car from my country to my holiday home in the UK? Additionally If I replace the decat with another version which is a decat shell will it solve MOT problems? Thank you in advance, |
30th Apr 2022 5:45pm |
Question was not meant to agitate, as the only reason for changing the CAT/DPF is for more stress free ownership and not having DPF and Catalytic convertor problems.
Additionally a quick search of google, similar questions where raised by your own national's and a more laid back response was given this forum and others. As to breaking laws, the head of your government Mr Boris Johnson would probably be more of a concern hosting private parties during lockdown and is a prime example of breaking the law. Happy Motoring and |
30th Apr 2022 6:30pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3644 |
EGR close wont be picked up
but the lack of a DPF and CAT probably will depending on the vigilance and knowledge of the tester, have you still got the original bits that you could refit DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
30th Apr 2022 7:06pm |
Yes I do have them, thank you for replying politley.
30th Apr 2022 7:07pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Decat shell should be ok - depends on how vigilant the test station are. Rgds.
Chris Last edited by Pacha on 3rd May 2022 10:42am. Edited 1 time in total |
30th Apr 2022 7:25pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
In my experience it won’t be a problem at all. But you should have all these items to comply to the rules. So if you import the vehicle, bring the removed items, but then find a friendly workshop, and carry on storing the parts.
30th Apr 2022 7:50pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6095 |
I'd be bringing the G55 over instead!!
1st May 2022 6:33pm |
Thank you for the replies,
For the DPF to work properly the car has to see highway drive of 40 minutes once in a while? |
3rd May 2022 9:55am |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 289 |
The DPF regen is not related to time, but engine temp + pressure drop across the filter + speed: only if the parameters are meet a DPF regen will occur. (or thats how I understand it works on the 2.2 puma).
The manual states if short journeys are undertaken, the DPF may light amber, if that is the case then regen is requred : high range, main road or mororway (40-70 mph (64-113 km/h)) for 20 minutes or more; when regen is complete DPF light will extinguish. In the 3 years of having my 2.2 puma never had the DFP light or any issues with the DPF Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
3rd May 2022 11:04am |
Thank you.
3rd May 2022 11:30pm |
itsdashy Member Since: 20 May 2021 Location: Reading Posts: 72 |
It will really depend on the certificate of conformity and how much the person inspecting cares.
2nd Jun 2022 8:17am |
