Home > Maintenance & Modifications > Ignition barrel maintenance? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3678 |
Abus do a specific lubricant for locks, I use it on my external barrels and fuel cap after that started sticking. I imagine it would be suitable for this as well.
28th Apr 2022 5:09am |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 359 |
Will try and see if it's available here, but I doubt it. Lubrication of locks isn't a big thing in Africa
28th Apr 2022 6:12am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3421 |
The reason why lubrication of locks is not recommended the lube will attract dirt, and dirt will make it worse. Possibly this also applies for the ignition barrel, especially if you keep the vents under the windscreen open.
Best lube for locks is actually graphite powder, as is a dry lubricant. If you cannot get hold of graphite powder, just run a pencil (without the wooden part) on sand paper, and voila instant powder Just bear in mind that the ignition is made of 2 main components- the lock itself and the switch behind it. It could be a switch problem not a lock problem. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
28th Apr 2022 6:33am |
Another vote for graphite powder - it's like magic. Darren
28th Apr 2022 7:39am |
I know about graphite but how do you get the powder in when the lock is mounted?
28th Apr 2022 8:14am |
Generally comes in a small bottle with a nozzle (applicator) and you can ‘puff it’ in. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
28th Apr 2022 8:32am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4216 |
I used to have a can of dry graphite lube in like a solvent suspension. You squirted it in with an aerosol, the solvent flashed off leaving the graphite behind. Something like this: https://www.silmid.com/lubricants/graphite...l-Aerosol/ 2007 110 TDCi Station Wagon XS
28th Apr 2022 11:10am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 732 |
Or rub the graphite on your key and insert a few times
28th Apr 2022 11:12am |
I might have some Spanjaard Air Dry Film.
28th Apr 2022 11:59am |
