Home > Maintenance & Modifications > Naka rear door strut AND a swingaway carrier?
Gasket
Hi folks.
The back door on my puma has always wanted to flop closed and won't reliably stay open.
I'm planning on fitting a table to the door for a cooker and I also have a Mantec Wheel carrier ready to fit - so planning on doing both jobs at the same time.
I have also been planning on fitting a Nakatanenga gas door strut too.
But it dawns on me that the piston in the swingaway carrier and the Nakatanenga door strut might be OTT.
Could anyone advise?
Post #950684 26th Apr 2022 11:00pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
I’ve got this exact set up one my 110. I think I have version 2 of the door strut, the one that is positioned at the bottom of the door in the same position as the original. Works well to keep the door open and is easy to open. Closing the last bit can be a bit stiff but I find it a good upgrade overall compared to the original.
Post #950685 26th Apr 2022 11:34pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I've got the v2 ram fitted at the bottom of the door, plus a Britpart wheel carrier and it works well Thumbs Up It can be a little stiff to close but that's probably my fault for not oiling the moving parts of the wheel carrier as regularly as they should be. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #950709 27th Apr 2022 9:09am
geobloke
As above: V2 lower strut with wheel carrier. Easy to open. Holds open even on a slope. Heavier to close than standard.
Personally i prefer this than the closes on you on any slope with the weight of the spare wheel on the door.
Post #950710 27th Apr 2022 9:29am
If it were me, I'd fit the wheel carrier first and see how it is. You my find that it provides enough resistance on its own. I've got a Britpart carrier on mine, which I'm very pleased with and don't feel the need for an additional door strut. Darren
Post #950711 27th Apr 2022 9:35am
sewinelwy
Hi all!
Firstly I'm not a new member, have been since 2011 but somehow it all disappeared so had to re register!
My question is about the rear gas strut from Naka, wanted to fit one for 10 years but never got around to it. I finally bought the version 2 and fitted it yesterday. Now here's the problem! When I installed it, as per the data sheet pictures supplied I checked its function...... masterful! what an aid in every respect.
So, then I reinstalled the rear door trim and found that on closing the rear door the strut reaches an angle at about the mid closed position where it comes into contact with the internal rear door trim at the point where the relief for the factory stay molds back into the flat part of the trim panel. This results in the door trim being popped of of the door frame in that bottom corner, so strong enough to overcome the resistance of the door trim fixing clips.
Just wondered if anyone else has had similar issues. By the way I'm an ex engineer having spent quite some time in the automotive reearch and development side of things so I don't feel that I've installed it incorrectly. To me it looks like the internal tub mounting bracket supplied is fractionally to long and is creating too great an angle at that mid closure point.
Post #950728 27th Apr 2022 11:04am
PocketFred
Switzerland 2001 Defender 110 Td5 HT Caledonian Blue
It is an excellent investment, especially for LHD cars.
- No issues with the spare wheel
- No issues with the door card popping out. 110 HT TD5 w/ PopTop for travelling
110 CSW 300tdi for hunting
Post #950729 27th Apr 2022 11:20am
The clash with the door card was a fairly common issue when that version was first released. I don't know if the design was updated to solve it but ISTR that the fix was to slightly deform the door car with a heat gun. Darren
Post #950732 27th Apr 2022 11:45am
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
FWIW I got rid of my Naka Strut (the version that mounted at the top of the door) after a few weeks of fitting a spare wheel carrier - I found it a struggle to push the door shut and I'm not a noodle-armed choirboy!
Post #950736 27th Apr 2022 12:17pm
