Home > Technical > Puma rear seats part
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Folks,
To foldup the rear sets and clip the frame up i think i'm missing some part either on the strap or the frame itself, had a look on microcat and cant find anything, anyone know what's missing.
Post #949823 19th Apr 2022 9:07am
AMBxx
the thing marked 16 is just a nylon strap. Easy enough to make your own.
If you're missing the other bit, you need to go shopping - that's what locks the seat down and provides support.
Post #949829 19th Apr 2022 10:18am
Anvil
Italy 2008 Defender 90 Puma 2.4 CSW Tonga Green
.. and in fact, it holds all the weight Smile
Post #949865 19th Apr 2022 3:44pm
shanecl
Hi Guys,
sorry I might have explained it wrong, i have the seat base support, its the clip i need to hold it in the folded up position, i have the strap also just missing the clip part
Post #950431 25th Apr 2022 9:24am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I believe the part you need is LR062679
This should be a 2 piece kit consisting of a plug/collar and a firtree that goes into it.
You need to order 1 for each side.
I've had a couple on order for a while with one of the main parts suppliers, but understand that they are currently on backorder with LR so have not got them yet.
I've not chased mine lately, so please do let me know if you manage to get some!
a word of warning, at one point LR sent out packets marked up with the correct partno Lr062679, but they simply contained a single standard pop-rivet! clearly someone at LR having an off day!
EDIT: this message prompted me to chase up my order. Apparently they're now on backorder on LR with no ETA. I may resort to plan B which was to set a nutsert into the frame and use a bolt. This will work fine, but I think (unless you have a right angle drill) that I'll need to take the frame out of the car to expand the hole to be the right size for the nutsert.
Thanks
Jon
Post #950435 25th Apr 2022 9:40am
shanecl
Ah brilliant thanks Jon,
I see LR Parts are stating they have them in stock, will order from there I think,
ugh have that happen a few times where i got the wrong part in the correct marked bag Rolling Eyes
Shane
Post #950437 25th Apr 2022 9:49am
jpboost
no, lrparts is who my order was with and just called me to say they're effectively NLA.
the service from them has been great, but clearly if LR don't have any, there's not a lot they can do.
Post #950438 25th Apr 2022 9:52am
shanecl
Ah crap, thats all we need Rolling Eyes i might order afew randowm fir clips and see what works
Post #950461 25th Apr 2022 11:32am
nitram17
Post #950491 25th Apr 2022 2:26pm
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
Worth checking the parts you have, the fir trees were in the parts box I sent. I pulled the straps out to separate the frames from the seats when packaging up.
You can clearly see how they connect in the photo from my ad.
https://www.defender2.net/forum/topic80140.html JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #952547 14th May 2022 8:03pm
shanecl
Perfect thanks Jonathan, sorry, it was in no way a dig at you. I read they break easy and assumed that's what happened,
I've 2 bolts i'm not sure where they go, can i send you a PM of the pics and see can you remember
Shane
Post #952691 16th May 2022 1:16pm
Lodelaner
It’s all good, just thought it would be worth mentioning in case you ended up ordering something you already have!
By all means send pics. I wonder if the spares might be seatbelt mounting bolts ? JB
Post #952701 16th May 2022 3:34pm
