![]() | Home > Td5 > Brake caliper replacement |
Ahhhh you got the same answer as me then...
OK, all ordered. Just need the DOT4 and some paint now
![]() Enjoy your ride on the train ![]() ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5899 ![]() ![]() ![]() |
Update:
1/2" 13mm multispline socket fits the brake caliper bolts 11mm spannner for the caliper to metal brake pipe Flexi to metal brake pipe 14.5mm ? Bu the good news is, the 13mm and 11mm bolts/brake pipe nut came undone OK. ![]() Regards John M0VAZ Econet Station 48 no clock |
Hope you got done what you needed to John. ![]() ![]() I will be under Miffy replacing a brake line not very far away... It never ends ![]() |
Well this was just a dry run to make sure the bolts will come undone. Parts not here yet. May as well wait until they arrive save dripping brake fluid.
Good luck with the brake pipe. Not at Bala yet. I might get an ice cream, but today is more radio comms stuff. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Is it worth a light smear of copper slip/grease/duralac on the brake pipe union to brake caliper joint? 1999 Defender TD5 110
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3494 ![]() ![]() ![]() |
I am doing it on the restoration project. Try to keep it out of the hydraulic system though. Just on the threads is fine.
Edit: I am using copper slip. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Yes you can, also some red rubber grease can be used for the brake unions as it has been designed for braking systems. ![]() |
Red rubber grease on order
![]() ![]() There is also an argument to be made for extracting the caliper pistons halfway and giving them a coating of RRG before fitting pads. Might help protect the pistons and piston dust covers a bit or for a while. At least that is what I will be doing when my new calipers arrive. Plus, I have just ordered some caliper paint ![]() ![]() ![]() |
Forgot to ask. How did your Bala trip go? Beautiful weekend up here. Loads and loads of Defenders and classic cars out on the A5, plus a couple of classic busses as well and I followed a Jag E-type home from the shops
Bala trip went well thanks. Got want we needed to and had a good run home.
ta for the tip on the RRG on the pistons. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
Which calipers did you go for. I fitted Britpart to the front on mine and they seem OK. I got Ferodo pads to go with them. As I was happy with them I also got Britpart for the rear as I have just had to change my rear axle case so thought it was a good time to do it as they were very tired looking.
I got a tin of brush on caliper paint for the front, but it easily scraped off even before fitting. I wiped the caliper down with brake cleaner first but did not a raid them - it was a pita trying to brush paint them. The rears I have painted with Lidls own high temp paint- easier as its a spray but you should bake it on at 160c for half an hour (which I didn't do). I did scotchbright them first I an not really expecting it to last, but we will see. Good luck with yours. Mick ![]() Click image to enlarge |
I bit the bullet and ordered Delphi ones.
I have some silver spray paint and might give then a coating before they go on. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
