![]() | Home > My Defender > 130 Camper Conversion |
Ratty43 Member Since: 01 Sep 2021 Location: Cornwall Posts: 87 ![]() ![]() |
Thanks for the confirmation, that was where I thought it stood which was why I was annoyed at the first garage when I specifically asked them if they could do it. Not that it matters really, I find the commercial speed limits feel about right in him!
Well following the MoT we celebrated by getting the bed finished, thanks to Wyvern's posts we decided that a proper slatted bed was the answer and he's certainly right, worlds away from a solid sheet of ply.
![]() Click image to enlarge The frame is rivetted aluminium box section and remarkably strong, I need to sort out some gas struts to make it fold automatically but a couple of batten props sees it stowed in the roof. ![]() Click image to enlarge We then celebrated by having our first night of trial camping with the new roof and the bed, I'm lucky to have an aunt who used to keep horses so we had the use of her field up on the moors. ![]() Click image to enlarge ![]() Click image to enlarge Dog certainly enjoyed it ![]() Click image to enlarge As did we, clear night with the BBQ loaded with birch logs and then a lovely morning to wake up to (the geese in the valley were loud!) ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge After that we cracked on with the ply lining and getting the auxillary battery installed. ![]() Click image to enlarge ![]() Click image to enlarge Hopefully this weekend will see the flooring down which will set us up for installing the framing for the water tank, worktops and storage. |
lolo Member Since: 18 Jul 2021 Location: Vaud Posts: 123 ![]() ![]() ![]() |
I enjoy following your project. Nice pic of your camp at night, this I guess was a very rewarding and enjoyable moment
Thanks Lolo, it was a really satisfying event, the first time after a lot of long days that things felt like they're coming together. Long way to go yet but it feels like we're on the home straight.
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 ![]() ![]() ![]() |
Glad I was able to inspire you in the bed build! - looking fab so far !
![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Great to get your first night camping done!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Thanks, it's starting to take shape now. I don't know why slatted beds aren't more common, I was a bit worried about the strength when climbing up but it's fine and really comfortable. |
I totally agree - the weight advantage alone is of great benefit, as to the comfort and air circulation ..
however each has their own merits I suppose! You will never finish the ’tweaks’ as its a life long project but - its getting close to the time to get out and go camping ! ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
katana069 Member Since: 28 Mar 2022 Location: Northern Ireland Posts: 44 ![]() ![]() |
excellent work, very inspiring!!
Thank you!
Weight wise the memory foam mattress is heavier than the frame and slats. I need to sort out some gas struts in due course to make it fold up into the roof correctly but the props will do for the moment. |
Busy weekend and a fair bit of progress to report. Started off by laying the vinyl so we now have a presentable and waterproof floor. This is laid over 1/8" ply on top of 10mm of XPS insulation.
On Saturday Sarah set to removing the other window and then bonding and rivetting in a cover from the rest of the aluminium left from cutting the hole in the roof. ![]() Click image to enlarge ![]() Click image to enlarge Anybody with concerns about modern sealant adhesives should have a go at removing things bonded with them, the only way of getting the glass out was cutting the adhesive with a multitool, which takes an age. Meanwhile I made a start on installing the water tank under what will be the indoor seating. The tank is an 80l one which should give us a reasonable bit of endurance. ![]() Click image to enlarge This sits tight against the wall and I then made a timber frame that clamps tight around it. On the other side the porta potti fits in nicely ![]() Click image to enlarge Complete with a useful sized gap for storing loo roll and the fluid for the toilet. The whole lot will be boxed in with a lifting seat section and door to the front allowing the toilet to be slid out. After that I spent part of today sorting out the auxillary battery with the T-max split charge system so we now have a second battery wired in. Each battery has a 150A mega fuse close to the battery in case of disaster striking. ![]() Click image to enlarge ![]() Click image to enlarge We're booked in for the Adventure Overland Show in June so there's going to be a few very busy weekends ahead to make sure we're something like ready. |
Well a bit more progress over the last weekend with the plumbing in and the lights over the worktop up and running
![]() Click image to enlarge I was a bit worried that the lights would be too dim at 0.4w but 4 of them work really well. We also got the stove worktop built and blocks in to try out the position ![]() Click image to enlarge It's really starting to feel like it's coming together now. I spent this evening bonding the Formica to the worktop and splash back. We also have the anodised aluminium on order for around the stove so this weekend should see it nearing completion on one side. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10867 ![]() ![]() |
Great work your both doing there and it's looking good
