![]() | Home > In Car Electronics > Battery box with split charging. |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1110 ![]() ![]() ![]() |
Very well executed
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3531 ![]() ![]() ![]() |
Very well planned too.
![]() Maybe just install ferrules on the ends of the wires that go in the split charge relay. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1466 ![]() ![]() ![]() |
Thanks both.
Ferrules. - yes, great idea, I'll get some. ![]() |
Update.
Just got back from the camping trip. All worked well, no issues and the Stornoway black pudding got home safely. Before the trip I made a new lower part for the box from plywood, stronger and with proper carrying handles. 2 tie down loops were added to the load shelf and a ratchet strap used to hold it down. The plywood board on top of the box is to spread the load on the lid. ![]() Click image to enlarge Before setting off the battery was fully charged at home and on the 3 days travelling to Stornoway the fridge was run from a power socket in the landrover. On arrival at the campsite the fridge was plugged into the batterybox, it ran for 4 days and the voltage dropped to 11.8v, still good for another day or so. (I turn the fridge off overnight, 10pm to 8 am to save power) On the 5th day I went for a drive and plugged the battery box in to charge it, came back with 13.8v. For the rest of the trip, 6 days, the fridge was left connected to the battery box, which was charged up every day while driving. No issues, no switches to remember, dead easy, use and forget. So for occasional use you don't need to spend £1000 plus on fancy batteries, chargers, wiring and battery trays. A simple leisure battery, a £12 relay and few bit and pieces will do the job. But it doesn't sound high tech and impressive ![]() |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2320 ![]() ![]() ![]() |
A man after my own heart, although the shame of finding a solution that is not reassuringly expensive may stay with you 😉😁
