![]() | Home > Maintenance & Modifications > dual battery confusion - separate leisure battery? |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1137 ![]() ![]() ![]() |
awesome
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1496 ![]() ![]() ![]() |
Rather than hijack this thread, I've made a post about adding a split charge to a removable battery box:
https://www.defender2.net/forum/topic83243.html ![]() Click image to enlarge |
carpetsauce Member Since: 19 Mar 2021 Location: Essex Posts: 58 ![]() ![]() |
Using a trailer plug to keep your battery charged avoids the inconvenience of cables appearing under doors or the bonnet.
If you have a trailer socket connect a fly lead to a trailer plug using the permanent power and the ground connections on the plug. Connect the fly lead wires to your battery charger (+ to +, - to -), put the charger in one of your partner's best tupperware to keep it dry. You now have an easily removable and inexpensive battery charging outfit. |
