Home > Td5 > TD5 rev counter hit and miss.
Procta
had the car running today, and then the rev counter just stopped. if i mess with the blowers it sort of comes back on line? when i fire the car up into life, all is working, but after a bit of a drive, the rev counter just goes like that,
 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #949397 14th Apr 2022 6:20pm
markb110
I am assuming you checked the condition of the wire going into the back of the ECU.
Unless its the unit itself i cant think of what else you can check part from the main earth strap.
Did this happen at the same time the rear lenses melted?
Post #949421 14th Apr 2022 8:27pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Have a look behind the dash.... sounds like a poor connection being jogged by the fan leaver. These weren't standard, it's possibly an after market add on so might have bodged wiring in need of a repair
Post #949426 14th Apr 2022 8:48pm
roel
You might check the voltage.
When my Alternator died while off-roading, on the way home the rev counter was the first thing that stopped working. Roel
2003 90 Td5 (2009-now)
Post #949467 15th Apr 2022 5:42pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
The tachometer on my Td5 receives its signal from the ECU not the alternator. I wonder if you have some connection or earthing issues with the instrument pack?
Post #949534 16th Apr 2022 7:11am
grafty99
As its down past the zero mark I'm pretty certain it'll be a power problem rather than a signal problem.
Mine sits like that with the ignition off, then when you turn on the ignition the needle rises to zero.
I'm sure you'll find a poor connection behind the dash binnacle Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #949538 16th Apr 2022 7:25am
Procta
cheers pal Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #949704 18th Apr 2022 12:30am
