Home > Technical > trailer light staying on
Procta
any ideas what is causing this to stop on?
 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #949398 14th Apr 2022 7:20pm
Andrew james
United Kingdom 2015 Defender 110 Puma 2.2 USW Indus Silver
Melted rear lights! Rolling with laughter
Post #949401 14th Apr 2022 7:42pm
90 Dreamer
From your other post it would appear to be your bulbs over hearing?? Possibly causing both issues.....
Post #949403 14th Apr 2022 7:47pm
Procta
what would be causing the rear bulbs to over heat? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #949405 14th Apr 2022 8:02pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
From your other post, have you checked that the brake lights aren’t on all the time? If so I would assume a corroded trailer socket causing the issues. Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #949410 14th Apr 2022 8:33pm
Procta
I will have a look at the trailer harness tomorrow, just in case something is a miss there. would it cause any harm if i just unplugged it? as it not in use at all. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #949413 14th Apr 2022 8:36pm
Defender SVX
No harm disconnecting the socket to diagnose the fault. Going by your other posts I feel you’ve got some earth, alternator or water ingress problems.
If you’re struggling to sort it I’m only down in Stockton on Tees I’ll gladly take a look. Formerly mao99999
55 86" SERIES 1
Post #949415 14th Apr 2022 8:48pm
Procta
i will keep you in mind Thumbs Up plus it would be great to meet another defender owner from the forum Thumbs Up . Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #949423 14th Apr 2022 9:35pm
Dinnu
I thought the trailer light only flashes with the indicator (and a trailer is connected of course). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #949425 14th Apr 2022 9:42pm
discomog
I know that Procta has been having trouble with brake lights recently but I would look at the trailer socket first as they are renowned for corroding. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #949432 15th Apr 2022 8:41am
When I resides my trailer socket after I had some issues with it which was a genuine one.
I fitted another that had LED test lights built in. I think it’s Sparex or something as a brand.
When I put it all back together I filled it with wet silicone and wet assembled and allowed to set once it was all wired and I’ve never had a problem since as it’s effectively sealed up completely.
I guess you could use electrical enclosure gel too but that maybe a bit “runny” and make it a little bit more tricky to do.
I added an additional ground to it as well. WeWillWin🇬🇧🇺🇸
Post #949450 15th Apr 2022 4:11pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Laughing Sounds about right
Post #949564 16th Apr 2022 12:25pm
AMBxx
It flashes once with the indicators even if something isn't connected. I spent a long time thinking I had an electricual fault. Embarassed
Post #949575 16th Apr 2022 4:00pm
Procta
well i have unplugged the trailer harness from the cars loom, just to see if that has is the problem, and it has made no difference.
I may change the rear break lights for the new units i have just bought, in case these are causing a problem, I replaced these before. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #950032 21st Apr 2022 9:11pm
Trailer light will be related to the indicator circuits unless it’s a common earth fault.
What relay do you have? Thumbs Up WeWillWin🇬🇧🇺🇸
Post #950033 21st Apr 2022 9:14pm
