Home > Tdi > Bosch VE tweaking
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
Bosch VE tweaking
Reading various articles about this and wanted to distill it to the the boost enrichment actuator - what is adjusted and what it affects:
1. boost enrichment diaphragm and rotating the pin - increases fuelling over entire range of pin travel
2. boost pin stop screw - how much extra fuel is added with no boost
3. serrated wheel (spring preload) - how much boost is needed to move the enrichment pin
Does that sound correct?
Post #949236 13th Apr 2022 8:01am
