Home > Puma (Tdci) > Efficiency improvements and miles to a tank 2.4 90 |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Driving round Mull, very little stopping on most of the roads as it wasn't peak season / max speed of 40 mph average. I usually average 250 miles to half a tank during normal driving a usual day is smaller farm roads and a motorway run at 60 mph, once a month I tow our horse trailer which is about 3 tonnes loaded for about 60 miles. 99% of the time I re-fill on 1/2 a tank so keep a note of the amount used, old habit for racing as we used to weigh the fuel in some of the race cars. But I just keep a running average of the litres used per 1/2 tank to check for any fuel leaks and running issues. |
11th Apr 2022 10:34am |
TXH90 Member Since: 19 Jul 2020 Location: Worcs. Posts: 54 |
Some great responses; I'm in bits at the ranges some people are managing to get Mantra is now 50-60 and only 70-80 for a little treat
Just got rid of my irksome VW Golf to scrapman so now have some more in the diesel fund I suppose. Or should that be repair fund |
11th Apr 2022 4:24pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 930 |
Standard td5 90 csw running michelin latitude Cross in standard size, usually 28 to 30 locally winter, summer this is more like 30 to 33mpg, slightly more on longer summer holiday trips with local trips included. 2004 Defender 90 Td5 CSW
2002 Discovery 2 td5 GS (gone) 1994 Defender 90 300Tdi CSW (gone) |
11th Apr 2022 5:48pm |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 |
The best I have ever managed is 375 miles to a tank (2.4 90) - 34 mpg.
This was a return trip from Bristol to Kent and I spent most of my time sat behind lorrys. 2011 CSW XS 90 |
11th Apr 2022 7:45pm |
It’s still depressing when my wife’s car weighs more than my TD5 110 yet also gets nearly double the mpg (Octavia 4x4)
11th Apr 2022 8:56pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
them lorries must have been going too fast look out for the tall ones restricted to 50mph |
12th Apr 2022 2:56pm |
Well this post makes me feel a little better- at least I know I'm getting something inline with other 90s. Going to go steady on the accelerator when I can
12th Apr 2022 3:42pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
feathering the throttle and keeping below 1800 rpm in a puma can achieve really good mpg, go over 50 mph and it drops off significantly, remember that the throttle in high range gives 100% throttle over much less than 100 of the travel. (memory says 25% but expect someone will correct me)
I have found that moving from standard 235 continentals on 16 inch boost to 256 BFG AT2 on 18 inch bowler wheels has dropped my mpg 10-15% approx will experiment with higher tyre pressures DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
12th Apr 2022 5:15pm |
What pressures do you run your BFs on?
12th Apr 2022 5:19pm |
currently 34 front and rear DEFENDER 90 TDCI XS,
12th Apr 2022 5:52pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2651 |
i get 260-270 miles per tank on a 2.4 90.
Roof rack, 285/65/18 cooper zeon's hybrid turbo, ic exhaust etc.. |
12th Apr 2022 8:40pm |
robbie9999 Member Since: 07 Jun 2023 Location: Toronto Posts: 17 |
Stock 2008 Defender minus tires, running 31.5
Just drove to the 75th Jubilee in upstate New York, as per picture, I got a total of 712.3km= 442 miles. I kept it at 120km averge speed, could have easily got 725km, but got worried. Questions 1. Once the light comes on and needle is at empty, how much of a reserve is left ? 2. I am about to do a Stage 1 re-map anyone notice a differance in milage and or power ? Click image to enlarge Click image to enlarge Click image to enlarge |
22nd Jun 2023 2:06am |
I have had an IRB remap for several years.
Ian knows I tow a caravan and promised me loads of torque. I've noticed its loads smoother and extremely torquey, I can pull 6th gear at 50-55mph with the caravan and accelerate without changing down. 1st gear has also become redundant when not towing unless on a hill, I love it and it has not noticeably affected MPG, if anything its slightly better when driven in the 1500-2000 rpm torque range. Like others in mine high RPMs and speed kills MPG. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
22nd Jun 2023 7:26am |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 571 |
In my 110 SW with 265x65x18 BFG:
Day to day mixed 27mpg Long steady run 32mpg Fully loaded with roof tent 25mpg |
22nd Jun 2023 9:21am |
