Home > Maintenance & Modifications > Main beam Speakers |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 312 |
Sounds like a very unfortunate coincidence that the high beam has failed on both units simultaneously. As you've managed to get the high beam to work on the old H4 headlights you have eliminated a fault with the fuses, switch, wiring, earth etc.
11th Apr 2022 10:30am |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
What voltage are you getting on the high beam connectors? There is a very small chance this has fallen so low that it is beneath a cut off in the cree controller (but still be sufficient to light a standard bulb)
If you've got another 12-14v supply try it on the lights. If not.. probably a warranty job assuming they aren't very old. |
11th Apr 2022 9:10pm |
