![]() | Home > Puma (Tdci) > Cable stuck through firewall |
Niels906 Member Since: 04 Jul 2020 Location: Bussum Posts: 44 ![]() ![]() |
Hello everyone,
I am trying to thread a new antenna cable through a firewall in a tdci Defender. I manage to pull it through using the same firewall where the old antenna cable was. But after pulling the plug through it seems to be stuck behind a wireloom. Has anyone experienced the same? Any quick fixes, other than completely dismantling the dashboard, which seems like a pretty big job? All help is appreciated…. Niels |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
Removing the dashboard on a tdci is actually a breeze.
Then you are also sure that nothing is being pulled and no risk of chafing. While dash is off can check and improve rust proofing behind dash. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
