Home > Puma (Tdci) > 2.2. and 2.4 power difference.
Page 3 of 3 <123
X4SKP
Hello All
Can anyone confirm possibly ‘exactly’ the cross over date in 2011 when Land Rover
changed from the 2.4 to the 2.2 Puma engine… Question
Another approach (maybe) is to ask: Who believes they have a late 2.4 Puma… Question
and when was it first registered… Question
Reason for asking… I’m looking at a late May 2011 2.4 is that near the end… Question
Thanks… Thumbs Up SKIP
Post #948250 5th Apr 2022 8:55pm
Didn't the 2.2 come in with the change of model year, so around August? Darren
Post #948254 5th Apr 2022 9:06pm
MartinK
I bought one of the very last 2,4's. I even contacted LR at the time, who kindly told me where the last 6 had been shipped. I phoned all 6 dealers, 4 were sold, 2 for sale. I travelled all the way from Scotland to Mid-Wales to collect my 2.4.
It was "born" in September 2011. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #948271 6th Apr 2022 4:20am
Chicken Drumstick
ericvv wrote:
As per all my Defender brochures from 2008 until 2015 model years, the 2.4 and 2.2 are clearly identical power and torque. That was also always communicated like that by JLR at the change from the 2.4 to the 2.2 Puma engine.
Both are 90 kW/122 HP with 90% of that available between 2200 and 4350 rpm.
Both have a max torque of 360 Nm at 2000 rpm.
The main difference is the engine compression which is lower for the 2.2. (15.5:1 for the 2.2 versus 17.5:1 for the 2.4)
You clearly notice that difference when using engine brake to slow down going downhill. The 2.4 has distinctly better engine brake power than the 2.2. The 2.4 has an electronic speed limiter to 132 kph, the 2.2 saw that increased to 145 kph.
Eric
Published figures are just that.... it doesn't mean they are 100% truthful.
Also physics would suggest more displacement and higher CR will give different results on what is otherwise the same engine.
Also let's not forget the 2.2 existed before the 2.4 and the 2.4 was a bespoke designed and built for the Defender. If it made no difference, why would they have gone to all the effort? They only dropped the 2.4 because it was bespoke and cost more after JLR split from Ford.
Post #948292 6th Apr 2022 8:54am
Chicken Drumstick
Supacat wrote:
Interesting images. As they appear 100% identical I can only assume they are a copy & paste for marketing reasons. And that one of the graphs does not actually belong to the engine it claims.
Post #948293 6th Apr 2022 8:57am
Chicken Drumstick
Dinnu wrote:
I loved diesels that had a flat torque curve.
The tdci has the peak torque for a brief rpm range 😟
Personally, it feel like it needs a lot of gear changes to stay in the power band.
Interesting that the 2.2 and 2.4 have exact same characteristics. How is it possible with quite some physical differences between the two. I am not sure if I trust those charts.
No turbo diesel engine will have a natural flat torque curve.
Several factors firstly, the scale on the graph will change ho flat or not the curve looks. The scale here makes it look very sharp, but it probably isn't.
"Modern" engines with really flat curves are just using electronics to restrict the engine. i.e. the top of the curve is chopped off to make it flatter. But likely results in less PEAK numbers.
Post #948294 6th Apr 2022 8:59am
X4SKP
Hello LRA and MartinK
Thank you... and very helpful... Thumbs Up
I'd partly remembered MartinK mentioning previously he had a late 2.4 so thanks for confirming.
You may wish to skip the rest as I'm just expanding on my thinking
as we're now looking for a second Defender.
2.2 Vs 2.4
I've read most posts on this subject... and currently my reasoning is as follows.
Both are a good option, and more or less the only option post 2007.
I've got 100K experience driving a 300tdi and loved it...
but 'hated' the poor heater and demisting also long distance driving was somewhat
tiresome (I mitigated this to some degree but not totally or even enough).
I've now got 50K in a 2.4 Puma and again love it... for the way we use our Defender
it's just all round a better experience.
I've got 150miles driving in a 2.2 Puma and again had no issues
as they (2.4 > 2.2) feel very similar (although I acknowledge this is just one example against another)
the one issue I did notice was that (my) 2.4 has 'better' engine breaking than the 2.2 and as I was thought to drive in this style the 2.4 feels a better fit for me the 2.2 felt like an automatic to some degree when you easy off the accelerator it 'runs on' more freely than the 2.4... which some may like and may possible help marginally with MPG.
Anyway I guess I'm a victim to some extent with being inclined to go with what I know in looking to acquire a second Defender (its for my wife who put on 50% of the miles in the 300tdi) but only rarely
drives the Puma! but wants too!!
I do like the 'apparent' simplicity of the 2.4 over the 2.2 with a more straight forward Oil choice
I believe because of no DPF fitted, the omission of the Oil warning / Service interval light also
helps with this 'less is more'... 'rational' I've got going on.
I've looked after our Defender ownership now (for just over 30 years Shocked ) and a second 2.4 would be easier in as far as everything (more or less) is just X2.
Anyway thanks as usual for the D2N input... Thumbs Up SKIP
Post #948297 6th Apr 2022 9:13am
BrickBox
2.4 is my preference also. 2008 2.4 110 Utility Station Wagon XS.
Post #948299 6th Apr 2022 9:18am
I'd agree with the assessment of engine braking - definitely less in a 2.2 - but like most things it's easy enough to get used to. Beyond that though, I think that they're incredibly similar and that concerns over the added complexity of the 2.2 are overstated. If I were choosing between one or the other then I'd buy on condition rather than be wedded to one particular engine type. Darren
Post #948311 6th Apr 2022 11:08am
Sussex110
United Kingdom 2010 Defender 110 Puma 2.4 USW Corris Grey
X4SKP wrote:
Hello All
Thanks… Thumbs Up
Afternoon, mine is an October 2011 2.4 so I guess counts as a late one. Not sure when it was actually built though
Post #948320 6th Apr 2022 11:43am
X4SKP
The voice of reason (which we have come to expect... Thumbs Up ) and I agree Condition* wins out.
*appearance, quality and working order... +
(I'd add) ownership / servicing / mileage history. SKIP
Post #948324 6th Apr 2022 12:28pm
X4SKP
Hello Sussex110... I'd agree you have what looks like a very late one... Thumbs Up
Slightly Off Topic
From what I think I know there is a time-line of a few dates for each Vehicle that are ultimately 'key'
(well of interest to us Shocked )
LR Internal Build Date
I don't know mine.
Dispatched Date
My 2.4 was Despatched from Land Rover on 18th August 2010.
Sold / Registered Date
Mine was 'held back' then Sold on 10th December 2010.
This ensured the Classification changed from M1 to N1 with the VED (Road Tax)
advantage that Land Rover 'gained via the DVLA which then came into place for ALL
Defenders... therefore ensuring they equalled the then Utility Specifications Vehicles
and the resulting VED payable.
It's still amazing (to me anyway) that that this change went through... Shocked
I believe this crossover date (M1 to N1) was during either October or November 2010
(but don't know exactly).
I know for sure that it wasn't in place on 30 September 2010. SKIP
Post #948329 6th Apr 2022 1:04pm
BrickBox
The tax/category system I find strange.
M1 is more on tax but much cheaper on insurance.
N1 is much less on tax but then get stung with higher insurance for commercial. 2008 2.4 110 Utility Station Wagon XS.
Post #948333 6th Apr 2022 1:34pm
I think the latter very much depends on your individual circumstances. The insurance for my N1 USW is as cheap as it's ever been for M1 station wagons, even including business use. Darren
Post #948336 6th Apr 2022 2:27pm
Mines N1 2.4 90HT and the insurance has halved this renewal. Shocked
So I’m pleased with that! Very Happy Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
Post #948349 6th Apr 2022 4:01pm
Page 3 of 3 <123
