Home > Technical > Topless Defender with half-door
Arthur Mak
Hong Kong 2012 Defender 110 Puma 2.2 SW Orkney Grey
Brothers, I would like to convert my 2001 Defender 90 into a topless one. I want to use a series-style half door. Do the door for SERIES III suit the Defender?
Etc. Part number 395529 / 395530
Post #948286 6th Apr 2022 8:58am
X4SKP
Post #948300 6th Apr 2022 10:24am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Maybe add some kind of roll protection to that. I use the military hoop on mine for protection and to provide mounts for the seatbelts. It isn't fastened back to the chassis but is better than nothing and likely to be sufficient for the slow speed topple I am likely to suffer.
Here it is 2 weeks ago at a trialing event.
Post #948317 6th Apr 2022 12:33pm
I Like Old Skool
Also, I fitted the military 90/110 two part doors but these are effectively the same as the series doors.
You will need the correct door locks and catch plates and also need to modify the door check straps. I managed to graft in the check strap gubbins from my rotten Defender doors.
Post #948318 6th Apr 2022 12:42pm
geobloke
If you go the direction of having a roll bar then Safety Devices do a whole host of hoops and cages for a 90 soft top
http://www.safetydevices.com/expedition/pr...mp;cageno=
Post #948339 6th Apr 2022 3:59pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Re: Topless Defender with half-door
This kit may be of interest:
https://www.sp-4x4.com/DEFENDER_SERIES_DOO...wp7103.htm
Post #948341 6th Apr 2022 4:17pm
west4x4
Seen reports of the SP doors not fitting as have been made slightly oversized. Ifhou buy some measure them before fitting
Post #950016 21st Apr 2022 7:26pm
