Home > Tdi > 1994 Defender 90 Swivel Housing?? |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 |
Hi folk - I'm sure this will be quickly answered
I've purchased "One shot" grease for my Swivel joints but looking at my units I note perhaps three plugs which would I guess are related to my joints. Are these the older ones and require oil rather than grease, looking at some Youtube clips the designs changed at some stage around or after my year. Click image to enlarge ... and "IF" I use grease I guess I can simply fill from the top and check if "FULL" from the bottom plug, also some clips say to turn the wheel in or out ... does it matter Many thanks John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
3rd Apr 2022 12:23pm |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 358 |
Drain the oil and fill with grease.
3rd Apr 2022 2:25pm |
No need to check, turn wheel outwards when filling.
3rd Apr 2022 2:27pm |
Why am I missing something here Surely looking at my image, if you fill from the top ... it should come out the bottom when full (or visa versa) purging the air as it goes. Also heard of warming the grease to slightly "liquidify" it for better filling and air release 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
3rd Apr 2022 5:32pm |
One-shot is enough for a swivel pin housing.
No need to check, that's why newer models only had a fill plug. |
3rd Apr 2022 5:39pm |
Yep, get that JFH ... however, Mossberg paints an picture of air issues while filling the swivel from his experience. Surely it should be rather straight forward. 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
3rd Apr 2022 5:49pm |
I just used the bag, don't push it in all the way but keep a little space around the spout for air.
Take your time, you'll see with the first one. About 5min max to fill one. |
3rd Apr 2022 5:53pm |
Thanks JFH 2010 Defender 90 300Tdi CW (White/1994)
3rd Apr 2022 5:55pm |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
If you have a point for air to be expelled I would think it will be relatively straightforward. The issue with mine was the hole that I filled through just about fitted the tube. Unfortunately I didn't have a third plug I could remove. I tried filling with just the fill plug removed but it kept spitting it out, which ends up being messy. As soon as I removed the bolt out if the top pin it went in quite easily. I didn't warm my grease, but perhaps that would have helped. |
3rd Apr 2022 5:57pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 812 |
Maybe not the answer people want to hear, but why not fill with EP90 as LR originally intended?
This way you can drain out the old oil along with any contaminants/water that has found its way in before refilling with fresh clean oil. Never used one shot grease but coming from an off-road background have always wondered how you clean out the swivel housing if it does get any muddy water in there for some reason, and how would you know if you did? I reckon the first warning of any problems would be when the CV failed. With oil you can remove the level plug and dip the oil to check it's condition. |
3rd Apr 2022 6:19pm |
No need to warm up the grease.
The new models only have the fill plug, so you most probably, after going through deep water, have to loosen the seal at the ball. |
3rd Apr 2022 6:25pm |
Is it possible to top up with oil after using 1 shot grease? I know it kind of defeats the object of one shot, but at least its possible to maintain a level.
I got some one-shot a while ago and I had it a couple of months before using it. When I come to use it, it was separating into oil and grease. I managed to squeeze the tube enough to remix it before putting it into the swivel. I presume in the swivel the rotating CV etc would keep the grease/oil mixed together. |
3rd Apr 2022 6:55pm |
Every 4 years, when I do the big service (type C?), I buy one bag and I top up both if needed. I found grease in the diff oil.
But I have replaced all the seals there recently, so I will check the oil before I top up again. |
3rd Apr 2022 7:18pm |
