Home > My Defender > Heart still rules over head. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
fingers crossed for you
out of interest how many miles has it done? DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
2nd Apr 2022 3:57pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
I got sick of them as a daily. Now got a Golf R Wagon.
Ideal for Land Rover behaviour. Click image to enlarge There’s 5 in there, easily. |
2nd Apr 2022 4:02pm |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 |
54k. |
2nd Apr 2022 4:41pm |
cee-b Member Since: 25 Jan 2018 Location: South West Posts: 117 |
'The cheeky Censored at the dealership had also quoted me £4000 for work that needs doing (to replace the swivel joints and all 4 brakes need new discs and pads)!'
Just for info, I just had all that, plus new calipers all round, done for just under £1300 at a really good indy. Main dealer prices are k'in ridiculous. |
2nd Apr 2022 5:17pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 712 |
I Know exactly how you feel, I had a saga with my 300 after I cooked it(totally my own fault )
I had a load of problems after the original fix, which turned out that the over heating did a lot more damage than we expected. I had the same as you in regards to a garage that was more interested in mots than repairing, which resulted in more, constant problems. It’s a horrible feeling to have when, at least for me, I had over 200k miles of relatively trouble free miles. It made me feel, like I couldn’t trust the car any more, and I hated that. Finding a decent garage/indy was the difference between me having a car I can drive or an expensive ornament, I found a good one and they’ve been an absolute god send. |
2nd Apr 2022 6:32pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20347 |
Sounds like a tale of bad luck which sadly does happen.
I do get the impression that main dealers go for a new everything approach, with often replacing items that are very costly that don’t need replacing. After all, most people will genuinely listen to their advice, but there is nothing to say that said parts with vehicle hidden away out of the owners sight that the parts need replacing at all. The Turbo for example I highly doubt you needed a new one, I had actuator issues and all it needed was lubing the actuator arm pivots. I bet if LR had it they’d have advised a new turbo… Well they would wouldn’t they… Same if the actuator fails. You need a new turbo… no, you can get actuators recon or built new… (And very easy to change even for an amateur / DIY). VCV’s they’ll charge a fortune for and they do not need programming in. I wouldn’t be surprised if the VCV is at fault many have been sold a new fuel pump, and a “electronic re-learn” which isn’t needed on both accounts for a part that can be changed at home in 20 mins at for about £50. Worse than that is one main dealer can be fine, and reasonable cost, but another a rip off. When it comes to tech I can’t speak highly enough of Gary @ Alive, some of the electrics can be incredibly intricate and complicated. Martin is also very knowledgable with such things. When I think about the cost of repairs, I just remember it’s nothing compared to buying a vehicle. When you consider the new Def is what £560 or there abouts PCM and RR’s £1000 a month. Even other “cars” you are talking of north of at least £150 minimum a month + Unless you buy outright. That builds up a lot, you are talking for example of paying for one or two clutches a year or a complete set of tyres every year and the rest. I do believe in using Millers diesel additive permanently, as it will help keep things like the VCV, sensors, injectors, turbo, in better condition and less carbon and deposits build up. Whilst it’s not a miracle product, many diesel techs have sworn by it when an engine has been rebuilt. The worst jobs are the ones where you can’t drive it safely to an Indy or dealer. The whole thing with transport and having to arrange it all is a pain in the backside. When they are running nice it’s worth it though, you’d miss it if you didn’t have it. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 5th Apr 2022 7:46pm. Edited 1 time in total |
2nd Apr 2022 7:35pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1211 |
A while back I let go of my Land Rover One Ten CSW and had a number of discoveries over the years. I missed the Land Rover straight way, it took me few years to end up with another Defender (as well of a Discovery ) so won't make that mistake again! I guarantee you will miss it as soon as it has gone off the driveway and the Defender itch will start again !! 2010 XS USW
1957 Series One 88 diesel 1958 Series One 88 4x2 |
2nd Apr 2022 7:36pm |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
Wow, I really feel your pain. I believe one of the main killers of vehicles in the future will be electrical and sensor faults.
When I bought my Defender I deliberately went for the 300tdi as I would not be able to handle any electrics. I hope with the basic nature of the electrical circuits of the 300tdi that I will be able to learn enough to get by, and if not I hope it won't cost an arm and a leg. I hope to be able to learn the basics of mechanics, but I know I won't be able to do everything. I hope you have better fortune with yours in the future. It looks like a nice example where mine is rough - around the edges and more! All the best. Mick |
2nd Apr 2022 7:51pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
It sounds to me like you need to find a good and competent independent specialist, since clearly the one you use doesn't know defenders and doesn't worry about fleecing customers whilst randomly replacing parts. The main dealer is not much better, perhaps not surprising as it is a classic Defender, a vehicle they'd like to forget about.
How on earth can a turbo actuator "coke up"? It's and external stepper motor connected to the movable vanes via an external linkage, so the turbo vanes could coke up, the actuator could fail, but the actuator cannot come up. I think, sadly, you've been "had" repeatedly. |
2nd Apr 2022 9:40pm |
I was over a barrel. The trouble was no-one had any availability, so I was thrown to the wolves.
Hopefully, I’ve found a decent independent but we’ll have to see. |
5th Apr 2022 6:55pm |
This is what I was thinking - I would say an attempt to flog a brand new Turbo. On mine when I had the issue with the actuator and vanes sticking, I ended up with limp mode till I got home. Since I lubed the actuator arm pivot points with a little 3 in 1 oil the Turbo has been working better than ever and with its full power output. Also, in the past when I did use main dealer servicing the props and UJ’s weren’t greased either, many things missed. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
5th Apr 2022 8:04pm |
The Anti Christ Member Since: 24 Feb 2022 Location: Kingston Posts: 26 |
Had a similar issue with the local LR Dealer. They had removed the bonnet while in for a Rear crank Seal replacement which involved removing transmission Then refitted the bonnet improperly, somehow manageing to fasten it long enough for me to get home. When I realised the bonnet wasnt re-fastening brought it back and was told that it would need a new bonnet catch and cable. After much insistance with the Service Manager, they agreed to adjust it as a "gratuity" since the Landy had sat there for an entire week prior even with a proper booking. Got it back with visible depressions in the bonnet.... too exhausted to go back and complain again. But totally agreed...
Theres nothing like a Defender! This after having lost use of her for nine months while an indie diagnosed failure to start issues when cold which eventually was fixed by servicing the fuel pump (Tdci 110)... Still have PTSD about taking her on long trips for fear of not being able get back or worse losing power on the way.
I know the feeling only too well my friend! Just fix it before your friends find out it broke again - Landy Life Forever! |
6th Apr 2022 4:30pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 334 |
Sorry you’ve been through such a traumatic time with it.
Mine’s a 2013 SW in firenze red too, so reading your description I couldn’t help but feel it could be me! Totally agree no other vehicle comes close to a defender (especially in the best colour!). Definitely a decision of the heart, not the mind, but (as I try to explain to my wife) nothing wrong with that! |
6th Apr 2022 9:14pm |
BJH Member Since: 14 Apr 2022 Location: West Wales Posts: 17 |
I was very sorry to read this tale of woe. The trouble with electrical issues that you can't diagnose yourself is you are then at the mercy of the 'professional' outfit that you submit your troublesome Landy to.
And here I do take issue with professional garages because part of the cost for the work is the diagnosis of the problem. And so I would expect that an incorrectly diagnosed problem would be at the fault, and therefore the cost, of the garage. But that's not how it seems to work. Instead they will make a guess as to the problem, present you with the option to go forward with it, and all the responsibility for the wrong diagnosis then rests with you! It's crazy. It's for this reason that it is important to establish a relationship with a garage you can trust. Easier said than done, I know. The battery diagnosis by the LR tech is frankly bizarre. Obviously I don't have the full and detailed information but based on what you told to us here, there is no way you go from that to blaming the battery. I don't understand it at all. Well, I am glad you at least got to the bottom of it in the end. And, I have to say, she looks great in the Sun. |
14th Apr 2022 9:51am |
