Home > Puma (Tdci) > Question
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
Question
Still trying to track down non starting issue have changed ignition switch earth cables and relayit is a basic spec 110 hardtop ie no abs central locking alarm question is the green box behind dash I thought it was for central locking could it be disabling start on this spec of truk any insights would be great pulling hair out now Endeavour To Persevere
Post #947012 25th Mar 2022 4:33pm
nitram17
Is it totally dead? does engine turn?if you've tried the usual :fuses.relays Earth, cables ect try the unusual ..check the inertia switch is working or the tdc engine sensor. Sorry is it a puma?
Post #947017 25th Mar 2022 5:01pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Green box should be for alarm and immobilizer on the base spec. Least it is on mine.
Post #947018 25th Mar 2022 5:03pm
110 Iain
Hi yes puma dash lights up as normal nothing happens when I try to crank no alarm as far as I'm aware no light for alarm but do have bow behind sdash not sure what it does on this spec Endeavour To Persevere
Post #947021 25th Mar 2022 5:21pm
nitram17
Have you tried the the power relay and starter relays under the drivers seat? Its usually an immobilizer prob but if you haven't got one!
edit i said fuse when i meant relays Embarassed
Post #947023 25th Mar 2022 5:48pm
110 Iain
OK she started no reason been dead for 3 days started of and on dozen times fired up each time but once a clunk from starter so now ordered new starter this ones only a year old now deciding if I can fit myself with my limited skills look like a pig to do by all accounts oh the joys of landy ownership thanks for all replys and support Endeavour To Persevere
Post #947029 25th Mar 2022 6:50pm
spudfan
Ireland
I think it is something to do with the key fob and communication with the vehicle ECU telling it to start the vehicle and here is my reasons for saying this.
Our 2008 Puma came with two sets of keys from the factory and both start the vehicle without issue.
The 2011 Puma came with one set of keys so I asked for a second set and got them. The second set had to be programed and mated to the vehicle by a main dealer. I left the vehicle in and this was done. If I use this replacement set it will sometimes give the non start issue which is cured by locking and unlocking the vehicle. So I think it is communication or in this case the lack of it between key fob and ECU.
I would suggest getting the key fob rematched to the vehicle. Fair enough I suspect the dealer did not do a great job on the keys they did for me but it is worth a try. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #947057 25th Mar 2022 11:59pm
Does the basic spec vehicle (without central locking) still have a passive immobiliser? The PI is a notorious source of non-starting problems.
Post #947086 26th Mar 2022 10:48am
110 Iain
Really not sure if alarm module present or used there is no alarm light on dash how would it arm with no central locking
Anybody out there with a basic spec utility 110 know Endeavour To Persevere
Post #947557 30th Mar 2022 7:27pm
Ianh
To look for alarm module remove drivers footwell speaker and with your head in the footwell look up through the aperture and you will see it.
See pics on this link which is for the later ALM ECU, the earlier AS10 looks the same but is green.
https://remotekey.co.uk/land-rover-keys-re...larm-ecus/
Post #947794 2nd Apr 2022 7:50am
