Home > In Car Electronics > Changed stereo - now battery goes flat! |
nick345345 Member Since: 05 Dec 2016 Location: Dunbar Posts: 71 |
Hi all,
I recently swapped the original stereo in my 2012 TDCI for a JVC KD-X561DBT and updated all the speakers to Focals. I thought it would be a simple swap, and all seemed to be going well, until I realised that the battery now goes flat after 3-4 days of not using it. I didn't change anything else at the time, I didn't do anything complex, just unplugged old stereo & speakers, plugged in new ones. Anyone experienced similar and could point me in the right direction to investigate? thanks Nick |
30th Mar 2022 8:17am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2313 |
Back in the day when I was more car audio inspired I recall this was an issue with the switched and permanent lives.
The red and yellow wires at the back of the unit should be on bullet connectors, swap them over so it is red to yellow and yellow to red. Try this and see if the battery remains charged. Also test to see whether the memory still remains after you switch it off and on again (check that the unit does not lose its saved radio stations etc) > 110 XS Double Cab |
30th Mar 2022 8:39am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1083 |
Could well be the case. I'm happy with my old (as in tape-player-old ) Sony unit. I wired it to permanent live to use it without the ignition key (it's a nuisance in a camper). Only uses a few mA on standby.
30th Mar 2022 7:01pm |
Hi all, thanks for the suggestions - I'll take a look tomorrow in the day light. I think I remember that there was just a single big plug thing, (an ISO connector?) that I couldn't get wrong!
30th Mar 2022 7:21pm |
west4x4 Member Since: 23 Jan 2010 Location: Rutland Posts: 140 |
I’ve just had same issue. Be wiring further down past the iso plug. In my case both sources were connected to a permanent live.
15th May 2022 11:55am |
15th May 2022 11:57am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3446 |
My then girlfriends car had the radio 'professionally' installed. They also swapped the red and yellow wires, but the only downside was that the memory was lost on every ignition off/on cycle. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
15th May 2022 12:20pm |
