Home > Technical > Fuelling problem on 2.4
Grenadier
Morning all.
Fuelling problem. Need to know what to look for.
Start up is normal. Can be a big puff of smoke if cold.
During warm up idle, engine hunts. Can get really bad.
Eventually calms down but when heading off and pressing accelerator, unless really over-revving, fuel feeds cuts dramatically, if not stall. Certainly there's seriously lag and hunting. To almost zero. This game goes on until the engine is warm.
Then, if driving at steady revs (2000) on straight road, it's OK. Not super responsive but OK.
On roads with traffic lights and roundabouts, can be normal when warm (certainly when driving) but when pulling away from lights, jncs or roundabouts, can sometimes feel like it's cutting out or almost going into limp mode.
What thoughts?
VCV?
Pump?
Something to do with the accelrator?
Other?
Am in UK. Don't want to get stuck here.
Ta Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #947478 30th Mar 2022 7:30am
Naks
I'd start with the VCV --
Post #947489 30th Mar 2022 8:38am
hank
With the engine running, disconnect each injector connector one at at a time then reconnect.
Unplugging an injector will obviously cause the engine to run on three cylinders which will be noticeable. If you unplug an injector but do not note any difference in running then that injector is faulty.
Costs nothing and takes two minutes to rule out injectors.
I had running issues with mine for months. Did the Mass Air Flow Sensor and VCV but it turned out to be a faulty injector on cylinder 4 as per https://www.defender2.net/forum/topic53240-217.html > 110 XS Double Cab
Post #947496 30th Mar 2022 8:52am
Definitely go for the VCV first, put a little light oil like 3 in 1 on your turbo actuator pivots too.
If you have no clutch switch DTCโ€™s it wonโ€™t be that, so maybe as mentioned above.
When was the fuel filter last changed?
If you donโ€™t already use Millers diesel additive, it may help and you can use it permanently anyway like I do. KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #947534 30th Mar 2022 4:37pm
spudfan
Ireland
Yep out 2.4 used to surge forward and a change of the VCV sorted. It was just fitted without any relearning process. Opinion is divided on this but mine was just installed and everything worked fine. A main dealer would probably say that the vehicle needs connecting to their computer for a relearn. They charge for this..... 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #947757 1st Apr 2022 7:21pm
Same here Spud, VCV straight in and working perfectly.
In response to the OP I just thought of, clean the MAF and MAP that may be worth doing as well. KEEP CALM AND Drill ON
Post #947763 1st Apr 2022 7:28pm
spudfan
Ireland
Yep, do the simple stuff first. Anything you can get out,get it out and clean it. 1982 88" 2.25 diesel
Post #947768 1st Apr 2022 7:39pm
Grenadier
Thank you all. Yup, VCV. Kindly changed by Chris at CSK in just 20mins. For those whoโ€™ve wondered, no re-learn required. Now drives like a dream. Looking forward to throwing in the new BAS Intercooler and hoses, and getting the remap done Thumbs Up Monsieur Le Grenadier
Post #948121 5th Apr 2022 7:01am
