Home > Technical > No power to reverse lamp- assume reverse switch needed? |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
I’ve never had that problem myself but have read many threads on here that suggests it’s reasonably common. Some good guidance on here on how to get at the pesky switch
27th Mar 2022 7:57am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2270 |
Check the pins in the connector to the back of the lamp, they can rust to nothing.
27th Mar 2022 2:30pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4731 |
The fuse is clearly marked on the pull down flap. Mine is a 2.4 so I do not know whether your fuse is in the same place as mine but the hand book has a page with the fuses and their locations. Iwould physically remove the fuse and replace it to see if that was at fault.
I had an issue with my reverse light and here is how it was finally sorted. https://www.defender2.net/forum/topic81961.html 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
1st Apr 2022 7:13pm |
