Home > Maintenance & Modifications > Hinge Fitting Advice |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
Option 2, if the new hinges have the same bolt spacing as the originals then they will fit. They can however be quite tricky, especially if you're fitting them on your own.
I'm isolating at the moment but am not far from you so would be happy to give you a hand if needed? In the meantime, it may sound obvious but have you tried slackening off the the top hinge bolts? You may find the door is being pinched, preventing the second bottom hinge bolt from lining up. EDIT Something else to consider, are the threads ok? 1985 127 V8 Build Thread Series 2 109" Series 1 80" Last edited by Shroppy on 22nd Mar 2022 4:58pm. Edited 1 time in total |
22nd Mar 2022 4:44pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 833 |
Option 2. 2008 2.4 110 Utility Station Wagon XS.
22nd Mar 2022 4:45pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Option 2 - loosen (don't remove) the bolts in all 3 hinges and you should be able to line up the bottom hinge. Worked for me! Just because you're offended doesn't mean you're right.
22nd Mar 2022 8:31pm |
MikeSel Member Since: 21 Mar 2022 Location: UK Posts: 10 |
There’s a video on YouTube by The Doctors Garage of him fitting them. He has some tips in there, maybe worth a watch.
Mine should arrive today, so interested to hear how you get on. Good luck. |
23rd Mar 2022 8:10am |
The Fox Member Since: 24 Mar 2014 Location: Shrewsbury Posts: 94 |
This was my conclusion too - if the originals fit, why not these. I'll have a go at Option 2 later today (at least we've got some nice weather for it) and report back. Many thanks for the offer of help - I may well take you up on that! |
23rd Mar 2022 8:51am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1426 |
I had the same problem with the holes not lining up.
Something was clearly wrong, possibly why original top hinge broke In the end I fitted the door on the top and bottom hinges, so it fitted the aperture and swung freely. Then fitted the middle hinge, slotting the holes in the body to get the screws in. |
23rd Mar 2022 10:24am |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 569 |
Remember Defender were hand built, tolerances are a bit vague.
When I did the same on mine, I had to open out a couple of the holes in the body by 1 - 2 mm. Then a dash of Duralac when you fit. |
23rd Mar 2022 2:31pm |
