Home > My Defender > Done it again - 110 200tdi |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2171 |
Looks a cracking base.....
12th Mar 2022 9:14pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3646 |
I love a saved from scrap rebuild story, keep us updated DEFENDER 90 TDCI XS,
13th Mar 2022 7:23am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
Well done saving it, looks a worthy project! James
13th Mar 2022 9:25am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10817 |
What's said above 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
14th Mar 2022 7:56pm |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 933 |
Thanks all, it certainly is a worthy project.
I gave it a bit of a clean on Sunday so it didn't look quite so sad. No more green mildew on it . The engine starts very well and runs remarkably well. I'd be tempted to run it as is if it didn't look so rusty. The belts need replacing and the pulleys cleaning, then it seems to be mainly a cosmetic job on the engine. Time has not been good to bare metal components, lots of rust but everything working. Power steering works and the only light not working is the rear fog and the smashed ns repeater. Chassis needs a new osf outrigger but other than that it looks to be a clean up job. Rear 1/4 has been replaced and it good order, if a little rusty on the surface. Tyres have done very few miles 285/75/16 on what we're new modulars. Nsf wheel is rusty in one spot but other than that all OK. Seats are brand new exmoor trim front and rear. Also full front acoustic rubber mat (wrights or exmoor, not sure). New fuel tank and filler and rear suspension was replaced although now has rust. Bilston shocks. Goodies that came with include front radius arms, steering arms, new steering guard, discs, calipers and pads, springs and shocks. Plus boxes of polybushes and a new rear prop. I don't think it will take a massive effort to get it back on the road but need to consider what the overall plan is before I get stuck in. It seems to be quite a genuine CSW that has not been mucked about with too much along with its original engine with reasonably low miles. Given what I paid for it I can give myself a decent budget and end up with a cheap (relative of course), really sorted defender. Looking forward to bringing it back to life. Not forgetting the new doors I need to put on the other one. |
14th Mar 2022 8:51pm |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 793 |
Looks great, look forward to seeing more pictures. BORG - Bucks & Oxon 4x4 Response Group
15th Mar 2022 7:13am |
Bit of a clear out and a hoover. Looking and feeling better already.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Rear floor is incredibly sound underneath the matting. All the other floor panels are in great shape too. Click image to enlarge New fuel tanks, pipes and filler. And replacement rear 1/4/ Been so long since it was fitted and painted the paint is flaking off and needs a good clean and repaint. Metal is still sound though. Click image to enlarge Upper OS bulkhead needs some attention. It has corroded in a strange way here. Outer seems fine but no doubt a sand will tell me more. Click image to enlarge Click image to enlarge And some more of the stuff that was in it ready to be fitted. Mainly front suspension components Click image to enlarge And believe it or not, the rear was all new as well with the components all bought at the same time. These have suffered somewhat from not moving at all. Click image to enlarge Amongst the other stuff in random boxes - a new wide angle prop, stainless door and hinge bolt sets, more bushes, front brakes etc etc. Click image to enlarge Engine does look a bit of a state: Click image to enlarge Click image to enlarge But it does start and run well. Need to consider what needs to be done. Everything is all turning and moving as it should. The aluminium components do look a state so they will need cleaning (not quite sure how to do that) and also the rusty steel bits. Need a new radiator and then also probably a fair bit of pipework. Overall, a really good base and it could probably be put back on the road for not a lot of money. Tricky to work out how far to go with it and how soon. Given what I paid for it I could afford to have a new galv chassis fitted, replace all the rear suspension, do all the necessary repairs (bulkhead, doors, C pillars, sills). Or I could keep the original and repair as required. Time to consider the options yet, have a number of other things on the to-do list at the moment so must resist the urge to get stuck in |
21st Mar 2022 1:34pm |
Looks pretty good execept that bulkhead corrosion. Good buy!
Are you planning to keep or sell on? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
21st Mar 2022 2:43pm |
Tough question to answer.
It seems like a genuine, unmolested CSW with original chassis and engine which has also not done too many miles. I think it will be nice when done, however carried away I get. Cold be a good car and a nice, appreciating asset. On the other hand, I also like my other 110. Galvanised chassis and bulkhead, just bought 5 new doors for it, recon engine etc. Noisy and leaky but it gets me where I need to go to have fun and then back again, although not always with the same number of parts connected. A decision for another day I recon. I don't need to sell it which is, I suppose, a nice luxury. Just space on the drive and political clearance may be the issue. I could always pretend that as I have 2 that are the same age I can consider them part of the kids inheritance and aim to leave one to each of them, surely the boss can't be mad with me for looking at it that way? |
21st Mar 2022 5:09pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
Sound logic bodstruck, no way anyone could argue with a fair and just inheritance!
21st Mar 2022 5:21pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5208 |
the 200tdi is very easy engine to work on i found. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
21st Mar 2022 7:38pm |
