Home > Puma (Tdci) > Red DPF Lamp..what are my options? |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
you've had the red dpf light on for a few weeks now, no?
At this point you're probably going to need someone with dealer level tools to force a regen. Roaming around 🇳🇴🇨🇭 |
14th Mar 2022 6:08pm |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
Yes about a week but today was the first day we tried to drive faster than moving from parking spots so didn’t know limp mode was on.
I’d purchase a scanner to have handy to do this but can’t figure out which is reliable and reputable scanner tool to always have with us. |
14th Mar 2022 7:13pm |
If I find a used Hawkeye from a discovery can I possibly add puma 2.2 on it?
14th Mar 2022 7:26pm |
Well, finally the Autel MS906 arrived. Found one cost me my left teste but I don’t need more kids so it’s ok
Was able to get her out of limp mode, did a DPF spray and then ran at high RPMs after 20 min. Great amount of white smoke and junk. Then took it for an hour ride with the scan tool hooked up and watched the live data feed. All looked very good and I was able to do a regen on the filter via scan tool and got the soot level down to 2% if I remember correct. Just learning the capabilities of the scan tool but already proved its value. Quite a bit different process compared to my first 19j! Cheers! |
24th Mar 2022 2:59am |
