Home > Technical > Portable Compressor |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4636 |
Just got an email from Bearmach about portable compressors. Have a look at this link. Enlarge the photo and look at the box which states "OUSTRNDING PERFORMANCE"! Would you trust a product with that type of description on the box? Seriously any thoughts on the compressor? They also have a slightly more expensive heavy duty one.
https://www.bearmach.com/product/tyres-whe.../BA%202641 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
11th Mar 2022 3:11pm |
Chugga90 Member Since: 07 Sep 2014 Location: Bucks Posts: 208 |
I have one pretty much the same branded as Ring.
Does the job |
11th Mar 2022 3:32pm |
Always good to get first hand user input. I'm thinking of getting one . 1982 88" 2.25 diesel
11th Mar 2022 3:35pm |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 165 |
What about this one!
https://www.costco.co.uk/Tyres-Automotive/.../p/1109618 |
11th Mar 2022 3:59pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2611 |
Still have my original twin compressor TMax, about 15 years old and still as good as gold. It’s also very fast. Also For those that ride mountain bikes and set up tubeless tyres it makes life very easy. |
11th Mar 2022 4:08pm |
Forgot to say, I cut the power cable and added an Anderson connector to join the two back together.
The reason is that it can still be portable and connected via the crocodile clips to another vehicle, or even a spare battery if needs be. It’s so fast I can air up the tyres on the wife’s Velar when fully loaded when going on holiday and I set the TMPS to Heavy Load, and that just using it connected to an AGM battery without affecting its charge. I also have an addition Anderson plug connected to the passenger seat bos wired directly to my second battery. If you and they have it the twin version is worth it for speed alone. |
11th Mar 2022 4:24pm |
Any of these compressor come with "Recommended by Ann Summers" printed on the box? 1982 88" 2.25 diesel
11th Mar 2022 4:55pm |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 |
I have the Makita one:
https://www.toolden.co.uk/automotive/vehic...rwQAvD_BwE I already have batteries and an charger, so for ~£90 I think it’s pretty good. 2011 CSW XS 90 |
12th Mar 2022 8:14am |
I thought that you were looking to put air into your tyres, not suck it out………. |
12th Mar 2022 9:48am |
