Home > Tdi > Rebuilding the R380
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
Rebuilding the R380
So I found where the gearbox noise was coming from, my R380 finally lunched the 5th bearing after 575,300kms, I'm going to do a rebuild so need to ask what I should replace. Other than bearings and syncro's I was going to do the main and lay shaft, oil pump but what else?. All replies are appreciated Pat
Post #945227 9th Mar 2022 9:59pm
geobloke
Hi Pat. My R380 did the same thing, 5th went bye bye.
Done this myself. Before putting your order in (you are a long way from Ashcroft Transmissions) strip the box down and make a list of components. It is not a difficult job, just one that takes time and a few specific tools, press and pullers.
Post #945228 9th Mar 2022 10:03pm
PAT303
Thanks mate, I'm going to cut the bearings off, can't be bothered with pullers, the main shaft is not going to be reused anyway. I want to replace everything, the original lasted 24 years and I'm not interested in doing it again.
Post #945230 9th Mar 2022 10:29pm
geobloke
The only thing you really need a bearing puller for is the big collar on the output shaft. It is a pain, but not impossible. To get it off I used a large bearing puller and a little heat. Took about 20-30 mins to get off. To get back on again it was the old pipe, bolt and stack of washers method. Worked a treat.
When my 5th gear blew it took made a right mess of the housing, chewed it right up. The suspect was the HD support bearings that had worn incredibly badly providing enough play to skip gear teeth and breaking them.
It was a huge bang whilst cruising on the flat.
The first and only time I have been flat bedded home Rolling Eyes
The mess of the bearings, gears and box
Bearing puller for the collars.
Good fun this job. Just be super clean when refitting. And if you need inspiration our LR guy at Britannica has just done a 12 part rebuild of a TD5 era R380
https://youtu.be/1cz7ohSLxK8
Post #945273 10th Mar 2022 10:17am
PAT303
I will cut the collar off and replace it with a new one, save me the hassle.
Post #945293 10th Mar 2022 1:13pm
Fatboy Slim
Wales
I've done a load of them over the years. You'll struggle to cut the collar off to be honest, because half of it is inside the seal/rear housing.
Post #945531 12th Mar 2022 1:27pm
