Home > Technical > Can +2” Shocks be used with std height springs? |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 |
@felixp how did you get on in the end?
7th Mar 2022 11:42am |
Certainly does suit it, looks great!!
Did you find you've ever inverted the roll bar then? I guess roll bar spacers is the easiest way to fix this, i'd not thought through it really. I love this idea of this...... switchable roll bar. https://foundry4x4.co.uk/index.php?route=p...h=x+deflex Might try one. Just checking - you fitted only the parts listed by badger in the end or did you need additional? |
9th Mar 2022 3:27pm |
felixp Member Since: 29 Oct 2020 Location: Bavaria Posts: 39 |
No not yet, that's why I didn't solve the "problem" yet But I have a fitting box section in my garage.. just have to do it.
Here are the parts I used: Click image to enlarge |
9th Mar 2022 4:02pm |
Superb thanks for sending it.
Do you think the isolators made much difference at the front? |
9th Mar 2022 6:23pm |
Hard to tell... as I also changed the shocks at the same time.
The reason I installed them at the top and bottom of the spring was for the quick & easy minimal lift. |
9th Mar 2022 6:25pm |
