Home > Td5 > power steering pump |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Close to turning the 200,000km mark on my 110 and the power steering pump is leaking and in need of replacement.
Several options out there, from an expensive Genuine one, to lower priced Bearmach, Britpart, Allmakes etc. Any recommendations / experience as the preferred replacement? Don't mind spending on the Genuine if it's a superior part, but if any of the less expensive ones are comparable quality, I would prefer to save my money to spend in other places. it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
18th Jan 2022 6:59pm |
I confess I went for a Britpart item and it has and continues to do what it is meant to do without leaking The quality was good and IIRC it was made in the UK as well
Bearing in mind that the PAS pump also drives the water pump it might be worth buying a replacement one of those as well. For what they cost, you'd kick yourself if you got in there and noticed a weeping seal. Plus it is a great time to do a full engine flush and coolant refresh ready for those hot Vancouver summers Oh and a spare drive belt for your stocks too. |
18th Jan 2022 7:31pm |
cocker Member Since: 23 Sep 2021 Location: Merseyside Posts: 38 |
Just done mine went for a reconditioned one on an exchange basis
genuine and good value |
19th Jan 2022 8:15am |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Ebay seller rr_steering does a seal and gasket kit for the original Hobourn pump. About the £25 mark. Done a few now and they work great. Had loads of issues with aftermarket pumps, zero issues with rebuilt originals
6th Mar 2022 6:11pm |
6th Mar 2022 6:16pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Before committing to replace/refurbish. Have a check for any backlash between the PAS pump and water pump. I found the drive coupling between the two had worn down substantially on mine (waterpump shown but PAS pump was almost the same:
Click image to enlarge Steve 02' 110 TD5 Double Cab Rebuild Thread |
6th Mar 2022 7:32pm |
