Home > Maintenance & Modifications > Door alignment
NFIN02
United Kingdom 1989 Defender 90 300 Tdi HT Chawton White
Door alignment
Hey all, see image below. Passenger door, gap at top and really misaligned. Drivers door perfect 💁🏼
Post #944270 1st Mar 2022 5:31pm
And your question (if there is one)?
You need to adjust the door, or possibly replace the hinges.
The picture below shows the ex-factory fit of the offside second row door of my DC. Rolling with laughter
(And they say that the Great Wall of China is the only man-made thing visible from space)!
Post #944272 1st Mar 2022 5:54pm
NFIN02
School boy question. How do u adjust door????
Post #944273 1st Mar 2022 6:25pm
Dinnu
Loosen hinge screws, lift door up to desired position, hold it there and tighten screws.
If it drops right away, either there is too much play in the hinges, or the screws are not tight enough. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944284 1st Mar 2022 7:31pm
markb110
Plenty of companies out their that will happily charge you plus £100k to put it right........plus other work.
One of mine is slightly off, it closes perfectly fine and doesn't leak so i'm happy to leave it be.
Post #944286 1st Mar 2022 7:54pm
Dinnu
There is quite some rubbing between the top corner of the door and the HT side panel... to the extent that it has worn the raptor finish. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944294 1st Mar 2022 8:32pm
Grouse
They did that from new
Post #944304 1st Mar 2022 8:54pm
