Home > Maintenance & Modifications > Retro fitting a heated windscreen |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2208 |
I considered it but by the time I'd priced up a genuine switch, relay, timer relay, fuse holder, wiring and connectors and then the effort to make it, it made the aftermarket harness price look more reasonable.
28th Feb 2022 4:21pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10722 |
I just went and got my heated windscreen and wiring all fitted by VGS they did the whole job while i waited, no problems so far and i'm very happy with it 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
28th Feb 2022 9:56pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2072 |
Have you tried MobileCentre? I recall they are on this forum and they certainly have a presence on eBay. Great service and very helpful |
28th Feb 2022 10:09pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17291 |
I made my own harness for my Puma. I emulated the factory wiring and in all honesty it was quite involved and time consuming. On the Puma the relays go under the seat, you need an "engine running" signal from the IPAC (special connector of course) and there are several wires to route from seatbox to dash, which is a hassle in its own right. It took the better part of a day to do.
28th Feb 2022 10:19pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 312 |
I made my own harness for my Td5. It doesn’t have the ‘engine running’ failsafe that the factory solution has but as long as you’re careful that isn’t 100% necessary. Fairly simple, using the genuine switch with a small internal modification as it is originally intended to switch the earth, not the power side of the circuit. The switch triggers a timer really which in turn powers the coil on a 70 amp relay which allows the high current to power the screen.
1st Mar 2022 10:02am |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 |
Have to say I agree with MO ... IMO, by the time you've got all the bits and completed the job you might as well have paid VGS (£132.00) or BML (£178.30) on eBay for the complete loom. ... and "Do it yourself" you get the satisfaction of doing it with no manufactures guarantee OR ... buy a "pre-assembled" one, paying a bit more and having a guarantee Then you're straight in to fitting it John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) Last edited by Cubflyer on 1st Mar 2022 11:45am. Edited 2 times in total |
1st Mar 2022 10:53am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2942 |
What was the price of a vgs supplied and fitted
1st Mar 2022 11:24am |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 809 |
also consider dan at pace automotive. Have brought one of his looms for the full overlay, very nice. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
1st Mar 2022 1:34pm |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
Thanks all, had a better look around now, and can get what I need pre-made for a reasonable price. Think I must have scared myself with a OEM supply it was £350! Seen a couple on ebay from £70 depending on switch so all good
3rd Mar 2022 10:41pm |
