Home > Technical > Defender 90 TD5 Alarm - Cobra / AS10? |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 571 |
The Cobra box is most likely just an extra immobiliser.
https://cobracartech.co.uk/alarms-immobili...liser.html |
25th Feb 2022 2:50pm |
andyg0141 Member Since: 25 Feb 2022 Location: Glasgow Posts: 28 |
Thanks. Would the AS10 be disabled when they fitted the Cobra? What I’m trying to get to is should I focus on getting the Cobra sorted and assume the AS10 is obsolete? Thanks
27th Feb 2022 9:21am |
No idea. You’ll have to all Time Team on it and do an investigation.
27th Feb 2022 10:17am |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 663 |
All Defenders shipped with 10AS’sThere are two versions, one simple and an ‘enhanced’ version with drivers for central door locking, battery back up option for alarm etc.
If you want an alarm, you can order the fobs online and activate the alarm and immobiliser functions of the 10AS. If you want CDL, you can buy the upgraded unit and swap out with yours and fit CDL units in the doors. There’s also an interior volumetric sensor you can too if you wanted. For your Cobra unit, if you can’t find it I assume the main unit has been removed, however, you could trace back from siren and see if it’s connected to anything. Last edited by SteveG on 28th Feb 2022 7:36am. Edited 1 time in total |
27th Feb 2022 11:39am |
Thanks for the info. I traced it back to the wiring at the AS10 unit and, having Googled the model of Cobra, found that it doesn't have a separate control unit; everything is build in to the siren (my fault for assuming it would have one).
Looks as though both are wired up so will order a new Cobra fob and see about coding it. Don't have Nanocom for checking the AS10 but will give my Launch diagnostics a go and see if I can see anything with it. |
27th Feb 2022 8:23pm |
