![]() | Home > In Car Electronics > I saw this and thought of you |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 577 ![]() ![]() ![]() |
![]() https://carpuride.com/ Looks to be an alternative to modifying the dashboard to fit a double DIN head unit. Anybody already got one of these? I'm seriously considering it. |
leonvh Member Since: 31 Dec 2013 Location: Plombières Posts: 69 ![]() ![]() ![]() |
I just installed something similar...
![]() Click image to enlarge Visibility is not a problem. I can change the position/height of the screen. |
Interesting. Do you some more details on the device you fitted?
It's a joying 8 inch 1DIN system (https://www.joyingauto.eu). Normally the screen is attached to the unit itself in the 1DIN slot, but I ordered an extra long cable (1M) to be able to mount the screen in a different location. In this case I used a generic RAM mount that I screwed to the back of the screen.
The unit itself is a purely electronic device that does not take up much space (more 1/2DIN). I mounted it a bit more inward so I could fit a cover. I still need to install the 4G and GPS antennas to get full functionality. I now have TPMS, OBD2, multi-USB, wireless Apple CarPlay and more than I will ever use. |
