Home > Modifications & Maintenance (L663) > Hidden winch mount Reul + Warn EVO 12s / High Beams 90mm
Defendit..
Netherlands
Time for the Big Mod, Warn winch..
Did my intensive research before, you only can spent once.
So no Warn Zeon platinum 12s, too expensive and not available.
No Landrover winchtray with crush cans, want it completly hidden.
Collecting my parts first:
Winchtray/mount / fairlead / flatlink from Reul Parts in Belgium
Warn VR EVO 12s (synthetic) with wireless remote
Relocation cables 0 awg for Winch relay under the bonnet
Solenoid / relay Kissling 500a / switch incab.
Nolden NCC 90mm 3rd gen Led High Beams with position and indicator.
Deutsch DT4 and DT6 ip68 connectors for wiring loom, cables & relay .
Brackets , sikaflex PU kit, additional hardware etc.
All new..
First mounting the Winch tray, testing position.
Looking for a place to mount the winch relay
First cutting the fairlead opening and right High Beam
My inspiration came from a render on a Dutch market place by Heritage
Licence plate positioning, bend it a little bit. second High Beam cutout.
Made brackets behind the grille for the High Beams, fine tuning can be done later.
Made the wiring loom with the Deutsch connectors, testing the position lights .
Connected the wiring loom today , according the video from Lazer lights. High Beams go over an relay for trigger 12v ( purple/Orange) Low Beam ( blue/green) direct to position lights.
So with the Low Beams on the auxilairy position lights work flawless. With DRL nothing, canbus thing I suppose.
Connected the winch with my new made relocation 0 AWG cables.
All in a flexible hose straight up to the engine bay.
Kissling relay/solenoid 500a
Fuse 450a
Final result
Leaving home light
High Beam with auxilairy High Beams
Indicators
So finally finished and I'am fully satisfied with it. Very Happy No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #938852 22nd Jan 2022 3:56pm
cyberhusky
Luxembourg
Nice job. How long did it take to finish? 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #938877 22nd Jan 2022 6:16pm
Defendit..
Netherlands
I will finish this project next week, will update. No Mud flaps for my 90.!
Post #938960 23rd Jan 2022 10:41am
Hazelhunter
Germany
Really cool job Thumbs Up
I like your ideas with the high beams... a lot of work -respect Bow down
Greetings from Germany
Post #939159 24th Jan 2022 10:29am
geobloke
Great effort. I forget just how beefy the Zeon winch is... That's one chunky bit of kit. Thumbs Up
Post #939167 24th Jan 2022 10:49am
Defendit..
Netherlands
Finished project
Wiring took some time and delayment.
High Beams work great.
Winch works very well.
2 little things left to do;
In cab switch for winch
Light smoke wrap for the new lights, to match the Headlights - Done, with Xpel slate smoke 50 headlight film.
Any questions, feel free to ask. No Mud flaps for my 90.!
Post #941534 8th Feb 2022 8:25am
cyberhusky
Luxembourg
I'm impressed by your work.
Do you have the Matrix lights on your Defender? 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #941571 8th Feb 2022 9:33am
JOW240725
Great work looks great! Thumbs Up James
Instagram @suffolk_rovers
Post #941575 8th Feb 2022 9:46am
Defendit..
Netherlands
Thx. I do have the premium led with DRL No Mud flaps for my 90.!
Post #941612 8th Feb 2022 11:58am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Nice job Mr. Green It looks great Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #941689 8th Feb 2022 6:13pm
01coccobet
Italy
very nice mod and detailed info.
I might follow this path in the futureā€¦..if it will be allowed.
Regulations, in Italy, are very restrictive Big Cry two gust is mei che one
Post #943882 26th Feb 2022 10:51am
Defendit..
Netherlands
Additional Recovery Gear ; Soft Shackle. (27,5T /60000 lbs.) From Amazon ( European warehouse France) .
Nice HD quality, great price.
https://www.amazon.nl/gp/r.html?C=3RIYO4PS...61_TE_item No Mud flaps for my 90.!
Post #947818 2nd Apr 2022 6:38pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Like that a lot, nice job Thumbs Up
Post #947832 2nd Apr 2022 8:57pm
Defgreen
Netherlands
Looking good, well done! Did you finish the switch-option inside as well?
If you get your inspiration from Heritage customs, be prepared for your next project Wink
Check their latest project on instagram... They are taking the roof of the defender 90 Shocked
Post #950595 26th Apr 2022 8:46am
Defendit..
Netherlands
Small update:
Every time I connect my IIDtool V4 to the car I got an fault for the lower vanes not detected.
Right I just unplugged and isolated them.
Found the solution in changing the CCF
MultiCAN-631 GrillActiveVanes - Upper and Lower Grill Active Vanes fitted
Changed into : Upper Grill Active Vanes fitted only No Mud flaps for my 90.!
Post #1041381 30th Jul 2024 1:19pm
