![]() | Home > Puma (Tdci) > Limp Mode |
LDH Member Since: 14 Feb 2022 Location: SA Posts: 7 ![]() ![]() ![]() |
Hi,
I am having the same fault symptoms as you had, did you find a solution? Cheers |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
If it's a 2.4 this could well be the VCV. |
I’m having same fault as Ben on 2.2lt p228c no over heating not scv no fuel blockage.unsure of tank pump supply pressure spec
BenA Member Since: 14 Aug 2021 Location: PE Posts: 5 ![]() ![]() |
Nope, still struggling with this one. Had all the sensors 'cleaned' and she was running like a dream for a couple of weeks. One session on a bad dirt road and up to her old tricks. We then tried to fiddle with 2 sensors at a time and thought it was narrowed down to the fuel pressure sensor. It's permanently fixed to the rail, great thinking, anyway new fuel rail and sensor. Guess what, wasn't that. Chugging along again, ready to throw a match at it. |
I’m thinking my tank pump is not suppling correct fuel to hp pump.trying to find correct spec isn’t easy.also I found fuel supply is connected to return in filter head,which seems odd.means fuel can go back to tank through filter head.have nothing to compare it to to eliminate fault with filter head.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20629 ![]() ![]() |
Probably something like Blackwolf said due to higher load. (The boost pipe and steering column is very close indeed!)
Lubricate your turbo actuator pivots and check it’s operation, it will cause you limp mode and happened to me. If it goes to under boost you’ll have basically no power, if it goes into over boost it’ll trigger limp mode and again no power. That can be as simple as the turbo actuator pivot points becoming dry and sticky and this making the electronic actuator work harder. It maybe pointless, but will cost you nothing. I’d suggest removing the top EA circlip on the top actuator rod, careful not to lose it.. And open and operate the turbo watergate up and down carefully it should move freely enough. Reassemble, and lubricate the two pivot points and the the piece where the actuator rod affixes to the turbo. I tend to just use 3 in 1 light oil in a dripper bottle, occasionally. You don’t need to do much and don’t spray lube all over the place or on the turbo it’s self especially not WD 40 or anything as the turbo gets very hot! It’s worth doing, but often easily forgotten to do. Even I forgot to do it and thus I had an issue with it. Actuator got stuck, over-boost triggered limp mode on then had to drive home luckily I was only about 10 miles away though I had no dash light on mine. DTC’s aren’t always guaranteed and sometimes you can get fakes which are non related too. Occasionally they can just be a good guide it isn’t fool proof. I only looked into mine as I saw overboost and I thought that’s turbo related and it was. Just an idea TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Cheers for that,have already checked and lubed the actuator,checked all intake pipes and pressure tested intercooler among many other things.more than likely fuel related as code implies hopefully not injectors or pump.
MSXuk86349 Member Since: 23 Feb 2022 Location: Cape Town Posts: 9 ![]() ![]() ![]() |
@ BenA _ I have been having this problem for ages. We've had the rail and sensors checked (main dealer so $$) then we had the fuel tank emptied and the fuel pump & filter replaced. The engine itself is running like a dream BUT as soon as you get onto a road where you can get into and cruise in 5th or 6th gear and then drive up a slight incline, it goes into limp mode. Makes overtaking a potentially risky action. The yellow engine light comes on. If you then stop and turn off the ignition, full power is returned (yellow engine light stays on) and off you go again. Has mainly happened shortly after changing into 6th gear, although today we had the same happen in both 5th and 4th. Any ideas anyone ? By the way, we had the other know PUMA 2.2 issues - blown turbo hose (LR replaced). Premature clutch failure (LR replaced). This has been the most troublesome Defender I have ever had. |
No, not resolved. I've been chatting to Linden above. Both struggling with similar symptoms and done lots to identify with no success. What is your error code?
Hi Ben,
Not sure but will check with the Indy who has been trying to get to the bottom of this. Perhaps refer him to this forum !!!!! |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 ![]() ![]() |
This sounds very familiar to me albeit on my 2.4!
I had something similar and ended up replacing a lot of things in the engine that didnt need replacing! Here's my thread... https://www.defender2.net/forum/topic75393.html To save you reading to the end...it was the head gasket! The thread does detail symptoms and all the things I did to try and trouble-shoot. One thing thats worth checking is after driving it up to running temp and leaving it for several hours, is the top pipe from the rad still pressurised and if you open the coolat cap, does air escape. Mine would stay pressurised over night. Also the RELD (sniff) test on the coolant never came back as positive for gas in the system so you can't trust a negative test. I was talking to someone at the time who also had the same issue and had his head gasket replaced recently. After doing all the same things I did, he had his garage take a look and they found the previous garage had fitted the HG wrong so it had to be done again. This fixed his issues too. |
I've wondered about this but I have no temperature issues when running live data....
Hi Greyman110,
Many thanks for the pointer to the thread. In my case there is no temperature issue either before or after the "event" which triggers Limp Mode. I am pretty sure that there is no smoke either. I am getting the error codes which my Indy has captured. Everything he saw seemed to point to fuel issues, but we have cleaned and tested and replaced. The main dealer tested the rail and sensors. But still we are stuck with it. True, you can turn of the ignition and re-start and full power returns as a "work-around" but it does not inspire confidence to go too far away ! Driving locally you would mostly not know there was an issue (usually in gears 1-5) but as soon as you hit the highway and get to more than 2300rpm in 6th, it goes. Yesterday, for the first time we had in in 5th - same circumstance of driving up a rise in the road and wanting a tiny bit more power. We also (yesterday) had it happen in 4th but hubby was driving and as a passenger, it felt like a slightly bum gear change after pulling away, that set it off. |
For those reading the thread, the Fault Code which comes up on the Analyser when this Limp Mode phenomenon occurs is : P228C-77 (28)
