Home > Technical > Help Identify this warning lamp?
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
Seems dumb to ask but can’t figure it out. If it matters I also have an orange CEL on too.
Post #943351 21st Feb 2022 8:05pm
ibexman
Post #943356 21st Feb 2022 8:22pm
big110
Guess my pic didn’t post. Sorry!
Post #943358 21st Feb 2022 8:25pm
landy andy
DPF issues.
Post #943365 21st Feb 2022 8:38pm
big110
As in perhaps it’s gelled up partially due to cold?
Post #943382 21st Feb 2022 9:51pm
I’ve never had anything to do with DPF stuff, but it probably needs a good hard run to heat up and burn off. I believe the DPF goes though a regen cycle or something where it needs to get hot so short journeys may bring it on. KEEP CALM AND Drill ON
Post #943386 21st Feb 2022 10:01pm
landy andy
I don’t know as I don’t have a DPF fitted. But that is what I assume that light to indicate, it has an issue or needs to be forced to regen.
Post #943387 21st Feb 2022 10:03pm
It does look like that. Thumbs Up KEEP CALM AND Drill ON
Post #943392 21st Feb 2022 10:50pm
Ianh
If it’s the red DPF light and the engine management light it will need diagnostic tools to check if the dpf is full, or if the dpf pressure sensor is giving a false reading, ether due to sensor , wiring or hose issues. If the dpf is full then a forced static regen can be run from a good diagnostic tool. It forces the engine to run at 3000 revs for circa 20 mins to get the dpf up to circa 600 degrees c, injects fuel into it and that should burn the soot and clear the DPF.
Did you get an amber dpf light before you got the red one ? That’s the sign that you have to take truck on a 30 min constant high speed journey to clear the DPF, if not done it clogs and you get the red light and engine management light.
You can check the pipes, see location in diagram https://www.lrworkshop.com/diagrams/land-r...10_2.2tdci part 21.
Some info on DPF’s and pressure sensors. https://www.delphiautoparts.com/gbr/en/res...ure-sensor
What diagnostic trouble codes are you getting ?
Post #943393 21st Feb 2022 11:07pm
big110
I’m
Not sure I noticed an orange light. Maybe I’ll take it for a spin and let things warm up and see what happens:)
Post #943394 21st Feb 2022 11:24pm
Ianh
Have you gone into limp mode ? As if in limp mode it won’t get hot enough to do a regen and clear soot.
I would check DTC’s first with an obd2 scanner.
If it did not show an amber light but went straight to red, and you have not been doing lots of short journeys without a long higher speed run then I would suspect the sensor, pipes or sensor wiring.
The DTCs will help diagnose this.
Edited my first post with more info
Post #943395 21st Feb 2022 11:31pm
Dinnu
It is also important with engines equipped with dpf that the correct oil with low saps is used.
Refer to this thread for a list of compatible oils.
https://www.defender2.net/forum/topic34176.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #943647 24th Feb 2022 11:24am
